Gidday all
I've had a good search but nothing on this (or others) forum that covers exactly what I'm asking.
I've got a 92 Safari running a GT35 turbo. Nothing, flash. My set up allows around 14psi using a 38mm wastegate. Unregulated the old girl can only reach 20psi.
Currently with the wastegate plumbed in, it begins to creep open at around 5psi. I can still reach the 14psi but not till around 3500rpm. If I take off the pressure line to the wastegate, I can reach higher pressures earlier.
Are there any ways to prevent this creep while maintaining the function of the wastegate to keep the boost capped at 14?
Wastegate Creep
tuckertrucker
sirLachlan
Re: Wastegate Creep
Read this to do it properly
Also it's worth finding the "part two" of that article on same page
http://www.autospeed.com/cms/article.ht ... 1&A=111348
The other option is just use a longer piece of vacuum hose to go to the actuator . Like actually just use a metre of hose and coil it up . See if that makes a noticible difference and it only takes 5 seconds to fit/try . Vl commodore owners do it quite often
The top link is thecnically correct and very diy and tunable for a professional result short of going to an ebc
sirLachlan
Re: Wastegate Creep
http://www.autospeed.com/cms/article.html?&A=111350
So in short get a low pressure adjustable relief valve and get a small one way valve .
The relief valve might cost some money . T fittings and hose and a check valve all should cost a few dollars each . Plenty of petrol cars have 5mm check valves for stuff in the vacuum system
Re: Wastegate Creep
simply get a ball and spring boost controller.
eg http://nxsmotorsports.com/
plenty of info around if you want to make your own.
tuckertrucker
Re: Wastegate Creep
cheers fellas, will have a read
Re: Wastegate Creep
External gate? Or internal.
If it were internal could be actuator preload
