As the title suggests, I've got a few issues with my 96 Nissan Terrano, QD32eti. Over the past few weeks, its started blowing huge clouds of white smoke out of the tail pipe when I start it, and will have a really rough idle until I give it gas to take off and it comes right. Note that when I'm driving it around, it behaves beautifully and drives well. It seems especially bad when I start it when its already hot. For example, I'll drive to the shops and park up. When i come back out and go to drive off, it'll idle low and rough, and bellow white smoke until i get it moving and it clears right up.
Just this weekend, I went to start it and it wound over once, then stopped suddenly. In hindsight, it seemed like it hydrolocking. I tried again and it wound, fired, but idled really roughly for a few seconds then died. I tried a third time and it fired up, idled roughly, smoked heaps, but came right after a few seconds and drove normally. I've also noticed it using a lot of water. It has a new, good quality radiator in it and no leaks, so that water is going somewhere.....
The cause could be the following: on a recent trip my partner said she could smell overheating, so I pulled over, popped the bonnet, and found the radiator was bubbling over. The temperature gauge didn't indicate anything unusual which is frustrating. I let it cool, topped the water up, and noticed that the radiator fan could be stopped with my hand - this indicates a buggered fan clutch doesn't it?
My gut feeling is that when the radiator fan failed on the recent trip, it's cooked itself and blown a head gasket. It's got brand new glow plugs in it and an injector pump rebuild 40,000kms ago, so I'd like to rule those things out, and when its cleared its throat after starting, it drives perfectly, so I doubt its a shot injector. Does this sound like a head gasket to you lot?
