B.J. And The Bear (70 Series)
fullthrottle
- Shuttle Queen
Yes indeedy-do. Picked up a new project today.
Doesn't need much doing to it, just a tidy up. The previous owner is kindly providing all interior parts so I can restore it to it's former glory.
Question is, restore, resto-mod, modify???
Will mull that over whilst I have a good play with it for a bit.
Re: B.J. And The Bear (70 Series)
Retore it if you can, not many mint ones around, they roll easy my son found that out couple months back
fullthrottle
- Shuttle Queen
Ouch! Hope he was alright. Heartbreaking for the truck. Can't imagine those fiberglass roofs hold much....then again, boats are strongbigstu wrote: they roll easy my son found that out couple months back
The more I research and uncover, some parts are like hens teeth to find. Thinking of a resto-mod. Full restore but with some added comforts of a modern vehicle. Will see how it goes.
First thing, sort the brakes out and a bit of rust. Plus work out how it goes into 4Low. Seems a little odd.
Where abouts are you, hes cutting cab down and putting engine gearbox and cutdown cab on an 80 series chassis, so has factory rollbar, diffs etc forsale soon, rear diff is a rare disc brake one he spent $1100 on just before he crashed, also has ironman lift springs and just put in new efs shocks and rebushed pined and shackled front and back.
Also rear panels etc available to chop for rust cuts
If u have manual hubs on it u still have to push the two buttons to right of steering wheel, then just the low high lever auto may need to be in neutral
fullthrottle
- Shuttle Queen
I'm Welly based. Sounds like a treasure trove of goodies that I need to visitbigstu wrote:Where abouts are you
Yeah I've got manual hubs and it's a manual. Engaged the hubs, depress the H4 button and the 4wd light pops up on the dash. But getting it into Low4 with the gear lever it a bitch. I have it in neutral, even hold the clutch in. Move selector from H2 to N, but won't go into L4.bigstu wrote:If u have manual hubs on it u still have to push the two buttons to right of steering wheel, then just the low high lever auto may need to be in neutral
Must admit, I haven't had a real good look at the linkage etc, but thought it would be the way I'm holding my tongue. Will do some more searching of the web.
Ha!! Had the same problem when I bought my first 80. Might just be the combo of settings and in the right order.
fullthrottle
- Shuttle Queen
First things first though. Clean up the PAJ, sell it off to fund the 70
https://www.offroadexpress.kiwi/Forums/ ... 18&t=47655
fullthrottle
- Shuttle Queen
Ideas, ideas....
**FRP**
I'm exploring the feasibility of some design ideas for the 70 and wondered if anyone knew how integral the FRP top is to the structure of the vehicle.
I'm assuming because it's removable, you can actual drive around with no FRP top here in NZ....legally?
If so, my next stage of investigation is separating the FRP into 2 halves. So I'll end up with a wellside ute with fully enclosed cab. Then use the remaining FRP top for a canopy. Little bit like the back half of an old Bronco...
**FRP**
fullthrottle
- Shuttle Queen
Here's what I'm aiming for.....
Rear doors and FRP can be removed.
fullthrottle
- Shuttle Queen
So a mate had some fibreglass flares lying around that he didn't want and so ummmming and arrrrrring if they would look like a good addition....
Definitly go the flares coloured coded they look great
fullthrottle
- Shuttle Queen
Ok, so time to get serious on this project. Starting with a full inspection of the good, the bad and to horrific.
Thankfully nothing too horrific that can't be easily fixed. Mainly rust, but that's fairly easy to cut out and replace.
One thing I definitely cannot fix is the rooted FRP canopy window frame. One is completely stuffed, the other looks ok. Will need to look for another one.
Full naked photo shoot here:
https://www.dropbox.com/scl/fo/11mncb3t ... dh2zw&dl=0
A few samples of the fun times ahead....
Should be able to save the door Peek-a-boo, I see you massive hole One of the rear quarters will need some love
fullthrottle
- Shuttle Queen
In no particular order...thought I would tackle the seating arrangement. The existing is something to be amazed at. Something that old hill Billy Bob would even roll in his grave at.
I have a fresh set of original seats, but also some reclining bucket seats designed for a 2 door vehicle. Having a play around with the mounting and might just go with the buckets.
fullthrottle
- Shuttle Queen
Ok, right, that's it, sort my shit out, on with the show.
Right so I have finally made a start. First things first see if it worth putting back on the road.
Some more inspiration... First off, the brakes are stuffed. Normal 70s thing. So time for an inspection. We'll hello, hello... I would say the brake cylinder has been leaking and has eaten the meat off the shoes. Other side isn't too back, but a full rebuild is in order.
I suspect it might also be an axle seal leaking, so have whipped those out and had a inspection of the diff as well. Oil is pretty clean. Little to now metal fillings on the drain plug magnet and no chips or wear. So I'm happy with that.
Taken off the brake backing plates and stripped everything back.
Ordered some new cylinders, shoes and seals. Time for a clean, paint and reassembly.
What else, we'll I scored some battery trays, so have rewired and mounted the batteries where they should be. In the engine bay and not in the passenger side foot well.
fullthrottle
- Shuttle Queen
Well that is much better.
Completely stripped down, repainted. New shoes, brake cylinders, axle seals.
fullthrottle
- Shuttle Queen
Righto, now for a front end refurb.
There is a fair bit of diff oil that's been leaking and upon draining the diff also a bit of water. Oil level was also low.
Leaking out from the hubs and swivel housing, so looks like a rebuild. If anyone has any seal kits knocking around, let me know.
Will pull it all apart and inspect everything to see what other surprises are in store.
One good thing, is that the underside, chassis and running gear is pretty sound. Only some light surface rust here and there to clean up. Will tackle the entire underside once I'm happy it can drive sagely.
Hows the build going?
fullthrottle
- Shuttle Queen
Well bugger me, I have been rather slack. Was hanging out in IH8MUD for a but. But yeah, plenty on the go.....
So what have I done...?
Well I've been wading around in pools of grease and oil. Well it seems like it anyway.
After rebuilding the rear, the front was next on the list.....Nice and shiny That looks a million times better now.... New everything...
fullthrottle
- Shuttle Queen
Now for the life of me, I had all sorts of trouble bleeding the rear brakes. I even ending up replacing the LPV.
But you wouldn't guess what the issue was. See if you can spot it in the photo...
A bloody tiny pair of vice grips......Mother F**kers
fullthrottle
- Shuttle Queen
Decided to get carried away underneath and replaced any leaking seals and then cleaned it up a bit...
fullthrottle
- Shuttle Queen
Been too cold to get stuck into the bodywork and do some painting...SO something else popped up that I couldn't resist.
Out with the old donkey and in with the new, fully rebuilt 1HDT.
fullthrottle
- Shuttle Queen
I'll be mating the 1HDT to the H55F gearbox.
I have a 1HZ bellhousing from OZ, and a new 1HDT flywheel and 300mm / 21 spline HD clutch from NZ.
Just need to make the input shaft fit. Possibly will add a spacer plate between the gearbox and bellhousing, or bellhousing and motor. Depending on where the clutch slave cylinder and starter motor align.
The 1HZ bell housing is about 5-10mm shorter.
