Pajero 2008 v6 3.8 exceed correct wheel rim offset
pchatz
Post by pchatz »
I am wanting to buy a set of black spoked rims and tyres for my Pajero however cannot seem to find what the correct offset is for my wagon. Some articles state -44 offset and some say +44/The mitis site says 44 but does not say if it should be + or - offset. Am wanting to fit a set of A/T's or Muds to replace some 20" mags with fake beadlockers. Can anyone advise what the correct offset should be please? After a lot of reading it appears to be +44 to +46 offset ? Has anyone fitted some to this model pajero and what size tyres did you go for? cheers,Paul.
UBZ
Re: Pajero 2008 v6 3.8 exceed correct wheel rim offset
Post by UBZ »
Measure your current Mags.
Half rim width minus the measurement from matting surface to rear of rim will give you your current offset .
Diameter of the rim is irrelevant it’s the width that matters .
Once you know your current offset you can decide weather you want the rims to stick out further (neg offset )
Personally I would stick with a 15x8 or 16x8 rim up to a 33” tyre. But some people prefer 10”
pchatz
Post by pchatz »
UBZ wrote:Measure your current Mags.
Thanks for the advice mate - Prob is I dont know if the wheels that are on it are correct.
johnny262
Post by johnny262 »
pchatz wrote:I am wanting to buy a set of black spoked rims and tyres for my Pajero however cannot seem to find what the correct offset is for my wagon. Some articles state -44 offset and some say +44/The mitis site says 44 but does not say if it should be + or - offset. Am wanting to fit a set of A/T's or Muds to replace some 20" mags with fake beadlockers. Can anyone advise what the correct offset should be please? After a lot of reading it appears to be +44 to +46 offset ? Has anyone fitted some to this model pajero and what size tyres did you go for? cheers,Paul.
Usually if positive/negative isn't clearly stated it will be positive, so factory will be 44P, though faily sure some were 38P. A 30 or even a 20 mm positive will look better, have a browse through the Paj forum I posted above.
NJV6
Post by NJV6 »
Factory Gen 4 Pajero is +46. Tritons and Sports are +38, and mostly dont fit Pajero's.
I have +35 and they sit flush with the guards on a 9 inch rim and 285 width tyres.
Dynamic do a 17 in steel wheel that fit a Pajero, not many 17's do due to the brakes.
Return to “Mitsubishi”
