this is the rock sliders (long peices) and all the plates that will be used to sandwhich the chassie in the middle and also the little peices will be welded to the plates and then to the sliders (if this doesnt make sense now it will when its finished lol)
my tubing that i think is about 3.2mm thick and is never going to dent or bend
i also had quite alot left over and i am going to build a simple removable roll bar (for WOF purposes lol) so i cut out the plates for inside the car and these will be the braces that will go backwards from the bar I also need to cut out another 4 plates for the underside of the car (this once again will be sandwhiching the body inbetween the two plates with the roll bar welded to the top plate inside the car) if this doesnt make sense now it will when its finished at martys work day on the 10th of feb
that is all for now
