**HELP WANTD 4 SPRING OVER AXEL CONVERSION ON A 413**
HEY EVERYONE,
I HAVE SEEN A FEW SUZUKIS HAVE CHANGED TO SPRING OVER AXEL TO GIVE ALOT MORE HEIGHT,I AM LOOKING AT DOING THIS TO MY 413 AND WAS WONDERING HOW I GO ABOUT IT??IS THERE ANY AFTERMARKET PARTS I WILL NEED TO BUY OR DO I HAVE TO MODIFY ANYTHING FOR DOING THIS?? ANY HELP WOULD BE MUCH APPREICIATED
CHEERS CHRIS
CHEERS CHRIS
where you see the flat bit that the spring pack mounts to under the diff housing, cut that off and weld a new one to the top of the housing so your spring pack can sit on the top......
if you cant weld or cut then you will be paying someone a lot of money to do this well enough to get certified for road use.
start reading
http://www.outerlimits4x4.com/ goto search and SPOA and select suzuki from the forum list...
same here:
http://bbs.zuwharrie.com/content/board,12.0.html
also here:
http://www.izook.com/tech/samurai/suspension/rrspoa/rrspoa.htm
Note: Samurai's/Sierras are basically same as 413's BUT there is WT and NT ones in aussi which are Wide Track and Narrow Track, most people prefer the Wide Track to do it on, and most of the older ones in nz <88 i think are all Narrow Track
same here:
also here:
- mushroom11
- Bush Crasher
his site will tell you what you need.all the info you need
http://www.zukikrawlers.com/showthread.php?t=174
i had my 413 converted to spoa.
i used the same springs just add a leaf at the rear to resist axle wrap.
torque bars will do. but that will be after you have done your spoa.
longer brake lines, longer u-bolts, you will need longer shocks.
make sure the drive shaft is aligned properly before welding the spring perches.
you might need driveshaft extensions.
If you can afford it, buy yourself a parts truck, or better yet, rolling chassis, and do the conversion on that first. then swap the bits over once you're happy. It makes things heaps easier, with much better access to all the bits and pieces, plus you can still drive your truck while you're doing the spoa. Do a rear disc conversion while you're at it. Like has been said before, get on the overseas bulletin boards and read up big time. difflock.com is another good one, English site with a bunch of helpful nutters
