**HELP WANTD 4 SPRING OVER AXEL CONVERSION ON A 413**
For all Suzuki related topics
sj-413
Post by sj-413 »
HEY EVERYONE,
I HAVE SEEN A FEW SUZUKIS HAVE CHANGED TO SPRING OVER AXEL TO GIVE ALOT MORE HEIGHT,I AM LOOKING AT DOING THIS TO MY 413 AND WAS WONDERING HOW I GO ABOUT IT??IS THERE ANY AFTERMARKET PARTS I WILL NEED TO BUY OR DO I HAVE TO MODIFY ANYTHING FOR DOING THIS?? ANY HELP WOULD BE MUCH APPREICIATED
CHEERS CHRIS
icekayak
Post by icekayak »
do you want to keep it road legal?
sj-413
Post by sj-413 »
YEH WOULD LIKE TO GET A NEW WOF AT SUM STAGE BUT COULD DO WITH JUST LIFTING IT FOR NOW AND MAKE IT LEGAL IN THE FUTURE.. IS THERE A QUICK AND EASY WAY TO DO THIS JUST 4 USING OFFROAD??
wopass
Post by wopass »
sj-413 wrote:YEH WOULD LIKE TO GET A NEW WOF AT SUM STAGE BUT COULD DO WITH JUST LIFTING IT FOR NOW AND MAKE IT LEGAL IN THE FUTURE.. IS THERE A QUICK AND EASY WAY TO DO THIS JUST 4 USING OFFROAD??
CUT AND WELD MY FRIEND...CUT AND WELD :wink:
sj-413
Post by sj-413 »
CUT AND WELD WHAT THO?? I WOULDNT HAVE A CLUE WHERE TO START HAHA
wopass
Post by wopass »
where you see the flat bit that the spring pack mounts to under the diff housing, cut that off and weld a new one to the top of the housing so your spring pack can sit on the top......
if you cant weld or cut then you will be paying someone a lot of money to do this well enough to get certified for road use.
icekayak
Post by icekayak »
ok if you wanna make it road legal it will need to be certified (unless you have a dodgy wof guy, and realise the insurance company probably won't pay out on it if you crash into someone...) which will cost $350 minimum...
rokhound
Post by rokhound »
Google in "SPOA for suzuki" and a do abit of homework before pulling anything apart.
That will give you a crash course on what you want to do. :)
icekayak
Post by icekayak »
start reading :D
http://www.outerlimits4x4.com/ goto search and SPOA and select suzuki from the forum list...
same here:
http://bbs.zuwharrie.com/content/board,12.0.html
also here:
http://www.izook.com/tech/samurai/suspension/rrspoa/rrspoa.htm
Note: Samurai's/Sierras are basically same as 413's BUT there is WT and NT ones in aussi which are Wide Track and Narrow Track, most people prefer the Wide Track to do it on, and most of the older ones in nz <88 i think are all Narrow Track :(
sj-413
Post by sj-413 »
oh yep cheers guys ill do a bit of research on it and decide where to go from there...
mushroom11
Post by mushroom11 »
his site will tell you what you need.all the info you need
http://www.zukikrawlers.com/showthread.php?t=174
lilpigzuk
Tiger Balm
Post by lilpigzuk »
what ever you make up for in height, make up for in width.... suzi's are good for falling over.....
faceman
Newbie
Newbie
Post by faceman »
i had my 413 converted to spoa.
i used the same springs just add a leaf at the rear to resist axle wrap.
torque bars will do. but that will be after you have done your spoa.
longer brake lines, longer u-bolts, you will need longer shocks.
make sure the drive shaft is aligned properly before welding the spring perches.
you might need driveshaft extensions.
vando
Post by vando »
If you can afford it, buy yourself a parts truck, or better yet, rolling chassis, and do the conversion on that first. then swap the bits over once you're happy. It makes things heaps easier, with much better access to all the bits and pieces, plus you can still drive your truck while you're doing the spoa. Do a rear disc conversion while you're at it. Like has been said before, get on the overseas bulletin boards and read up big time. difflock.com is another good one, English site with a bunch of helpful nutters
Return to “Suzuki”
