Does anyone use a bridle between 2 hooks? Wouldn't that halve the load between them? I guess its not practical if someone only has 1 on each end of their rig...
From http://www.offroadexpress.co.nz/modules.php?name=Forums&file=viewtopic&p=49159#49159
I have often thought about this and the effect it would have on the hooks
I am thinking that you would want the hooks mounted facing out on each side.
When I think of the anchors that I use for absailing and rock climbing the loading would be about 60% (some one correct me if I am wrong)
This would place the load in the best postion on the hook.
I had thought that side loading the hooks might stress the mounts but then I thought about some of the recoveries that I've seen and well ... they haven't all been in a straight line
I was thinking that maybee a tree protector would work well as a bridle and if you thread it through the eye of the recovery strop there would be no added projectiles.
What do you all think ???
