Surf bits STILL for sale
turoa
Pyro Junior
Post by turoa »
Help me finish the rover and buy some surf bits. It is currently on its side so you can view the mechanical bits. The body has some rust. It still has a 75mm bodylift which can be cut down to 50mm or something.
Please buy some bits
nzhunter
Post by nzhunter »
Mate mite b interested. What else is there?
turoa
Pyro Junior
Post by turoa »
nzhunter wrote:Mate mite b interested. What else is there?
Engine (most likely stuffed. Good if you want a 3y)
Gearbox and transfer case
Body
Canopy
Fuel tank
Chassis (still looks good)
Rear axle housing
All ifs front excluding hubs and calipers (4.5 ratio)
Some interior bits could still be good
Bonnet
Tailgate
Its a red 1988
Smurf
Post by Smurf »
is it the w56 box? after transfer case to suit . (the one with its own lever, not fed through rear of gearbox)
turoa
Pyro Junior
Post by turoa »
Smurf wrote:is it the w56 box? after transfer case to suit . (the one with its own lever, not fed through rear of gearbox)
Ill check it for you tommorow
JTop
Post by JTop »
Hi T
have you still got the FWH's, if so what make are they
J Top
turoa
Pyro Junior
Post by turoa »
JTop wrote:Hi T
J Top
Sorry JTop, I do have bits of freewheeling hubs, but they were stuffed and auto ones :(
turoa
Pyro Junior
Post by turoa »
It looks as if the lever is fed through the gearbox :(
Smurf
Post by Smurf »
bugger, cheers anyway Tu
bigstu
lift blocks
Post by bigstu »
hey how much for the lift blocks?
turoa
Pyro Junior
Re: lift blocks
Post by turoa »
bigstu wrote:hey how much for the lift blocks?
How does $120 sound?
