WANTED NISSAN DIFFS OR TOYOTA
mroffroader
Post by mroffroader »
Hey guys
any one have or know of any nissan safari front diffs (need a complete one) and need a 80 series rear diff (complete) there for the rover :twisted:
MUST BE CHEAP :lol: :lol: :lol:
doddzee
Is Doddgee
Post by doddzee »
Why not use nissan or 80 series front and rear? Why the mix n match?
MWB V8 Safari Ute
turoa
Pyro Junior
Post by turoa »
doddzee wrote:Why not use nissan or 80 series front and rear? Why the mix n match?
Nissan front will bolt in. You just need to make a hybrid panhard, and get a draglink made
Nissan rear wont line up to teh transfercase
doddzee
Is Doddgee
Post by doddzee »
turoa wrote:Nissan front will bolt in. You just need to make a hybrid panhard, and get a draglink made
Good enough Reason i spose :D
MWB V8 Safari Ute
mroffroader
may also consider the option of cruizer centers......so does anyone have some 40 rear diffs? need two......that is another option and get brian howat to make me some coustom axles 8)
DaveM
Post by DaveM »
hmmm, Nissan mixed with Land Rover mixed with Toyota = Tossan Rover
Mitchellman
Post by Mitchellman »
I am wrecking a 1990 nissan grandroad Have front diff open to an reasonable offer
mroffroader
Mitchellman wrote:I am wrecking a 1990 nissan grandroad Have front diff open to an reasonable offer
is it complete?? how much :lol:
Ryan
Post by Ryan »
what a cheeky prick askin 4 toyota stuff with that avatar?? :twisted:
mroffroader
Ryan wrote:what a cheeky prick askin 4 toyota stuff with that avatar?? :twisted:
:P
Dak
Post by Dak »
See, I told ya ya just need to buy a Safari to start with :twisted:
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
mroffroader wrote:may also consider the option of cruizer centers......so does anyone have some 40 rear diffs? need two......that is another option and get brian howat to make me some coustom axles 8)
I've got a 40 rear diff here, complete drum to drum. Two problems with these diffs in a Disco though, too narrow if you just want to bolt it in as is, the diff centre itself is too large if you want to fit it inside your LR housing. You'll need the 8" Hilux type heads. According to Howatt, 2 pinion only marginally stronger than LR Banjo (i.e. you or I will break it), 4 pinion the way to go, but even then he re-inforced the bearing caps on the ones in his RR as the carrier bearings are apparently a little on the small side.
Go the the Nissan GQ front and Land Cruiser 80 rear (or Salisbury rear and 4 pinion Hilux in the front)
turoa
Pyro Junior
Post by turoa »
No no cloggy, we are talking slicing the 2 housings in 2, and putting the cruiser housing diff holder thingymajig onto the LR housing. The guy who had a bobtailed rangerover at one of the rallywoods trips we did had done this.
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
That would work. Did this many years ago in my HQ, put a Ford 9" head mated to the HQ axles. Worked a treat as axles etc where the right size and spline.
Also have a 40 complete front axle here Mr O, the head is a little rusty though but some of Pedro's magical rust remover might fix this.
I was going to run these in my Series 1.
mroffroader
Cloggy_NZ wrote:That would work. Did this many years ago in my HQ, put a Ford 9" head mated to the HQ axles. Worked a treat as axles etc where the right size and spline.
how much i may be very keen :D:D:D
turoa
Pyro Junior
Post by turoa »
Whats gonna happen to the s1 body and cage etc?
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Mostly all gone. Sold, wrecked and given away. Just a few bits and pieces to go.
Mitchellman
Iam really new to this Diff is complete want $300.00
turoa
Pyro Junior
Post by turoa »
What ratio is it?
mroffroader
What ratio is it?
what he said :wink:
turoa
Pyro Junior
Post by turoa »
You've got a PM in your inbox :wink:
mroffroader
Il take it....where abouts are you? would you be able to ship to me in wellington? could you get a price maybe try main freight and ask for a depot to depot delivery. private message me with some details...
