Breathers
Sawdoc
Breathers
Post by Sawdoc »
I have just extended the diff breathers on my LN107 Hilux. Can anybody tell me if the gearbox/transfer case has a breather and if so were it is. Laying on the concrete drive way with a torch i was unable to find it :shock: :cry: Can anyone point me in the right :arrow:
SMOKEY
Post by SMOKEY »
Not sure if your hilux is the same as my LN130 surf or not. The breather for my surf is located in the plate that holds the gear lever in and I think it uses the same breather for the transfercase.
HEAVY BREATHING,
FITZY.
Sawdoc
Post by Sawdoc »
thanks Smokey i will check it out
Return to “Planning a trip?”
