Mitara aka da BEAST
Rotazuk
Post by Rotazuk »
Hey sorry straying here a bit again . On the rules on cutting guards does this include the inner guard ? On the rear of the vitara we are building I need to cut the inner and outer guard back to raise the edge etc . Also I have heard the comments you can cut the guard but not remove material . Whats the deal there .
Still waiting after six weeks now for the rules to be sent out to me from the assn , this is just crap :evil: . Can't start cutting until I have the rules . Grrr
Chris
Furgus
Post by Furgus »
Rotazuk wrote:Hey sorry straying here a bit again . On the rules on cutting guards does this include the inner guard ? On the rear of the vitara we are building I need to cut the inner and outer guard back to raise the edge etc . Also I have heard the comments you can cut the guard but not remove material . Whats the deal there .Chris
to quote from the "book"
7.3 Super Production Vehicles - Class E and F
L) Body
j) Wheel cavity interpreted as inner guard, outer guard, inner front panel & firewall may be cut, enlarged, flared, re-inforced or raised to the lower edge of the original bonnet height for tyre clearance only, provided no sharp outer edges are left which could cause injury.
If at first you don't succeed .... Get a bigger hammer!!
shell
James' Mum
Post by shell »
Image[url]
the body lift :twisted: [/url]
shell
James' Mum
Post by shell »
Furgus wrote:
doddzee wrote:Talking about the national trials, i have the booklet and in the current rules you are allowed to cut your guards to fit tyres. There are some rule changes coming up but i think it is more to do with the running of the events.
shell wrote:so with axle change to front end can you not instead of fiddles put disk's in the back and just use loss of traction to turn?
Im a bit lost with what you have written?? Im going to do a bit more reasearch into the disc rear before i cut the front out. Im not too keen on front fiddles, they load up the front end a bit much and do not help with traction as much as the rear fiddles will.
Just looking at the E Class rules it appears that you can
1. cut the guards to make the tyres fit - but no more - & sharp edges are not allowed (Shell :D )
2. fit disc brakes to the rear
3. get rid of the IFS & SAS it
& you can't
1. have tyres bigger than 33x14.5
2. change the rear springs
3. have any sort of lockers
if i do most of that, wat about a body lift? will i be in a competitive truck?
doddzee
Is Doddgee
Post by doddzee »
No im pretty sure you are not allowed body lift either. Lower the better anyway for trials as you want to keep stable on those sidlings. Just do lots more cutting. If you sas it space the front diff forwards a bit then you wont have the tyres clashing with the firewall.
Yes you will be fairly competitive in your class. Does yours have the 8 or 16 valve motor? A bit of a power upgrade might be a good idea aswell.
MWB V8 Safari Ute
shell
James' Mum
Post by shell »
well the body and spring lift is reverseable so thats good i still got the original springs :D not sure how many valves? :oops: but if i'm gonna re power it i may as well go full mod, wider diff's etc and run in another class. but for now i'm just a poor solo mum so i'll just see how we go, i do have to do most of the work myself so i struggle a bit, i just don't have all the tools i want or need :cry:
doddzee
Is Doddgee
Post by doddzee »
All those Mods will be expensive if you dont have the tools and have to pay someone to do them.
Keep it standard and enter a-class :wink:
MWB V8 Safari Ute
shell
James' Mum
Post by shell »
too hard she's already had a spring and body lift, so the work to cut the gards back and bash the hell out of the fire wall is gonna be too much at the mo :roll: so this year i think i'll do as much club stuff as i can then get her sorted for either a or e next year, provided i can drive :lol:
Mattman
Post by Mattman »
You should post on here when you need a hand. Myself and many other guys around here would probably be more then happy to help for a couple of hours and have tools etc.
Matt.
DieselBoy
Post by DieselBoy »
:roll: :lol:
wopass
Post by wopass »
DieselBoy wrote::roll: :lol:
:roll: :lol: :o :lol: :roll: :wink:
WACKO
Pyro
Post by WACKO »
Mattman wrote:You should post on here when you need a hand. Myself and many other guys around here would probably be more then happy to help for a couple of hours and have tools etc.
Matt.
so i'll be sitting on a deck chair drinking rum and coke while you boys fix up my truck :lol:
from shell :lol:
Hey our trucks need fixing too..... :lol:
warlord225
Post by warlord225 »
hey shell, I run 235/75r15's no rubbing at all, on standard wheels, so you shouldn't have needed to chop the body, maybe a spring and or a body lift.
