Fire Extingishers!!!
Hey if you don't have a fire extingisher in your vehicle, supercheap have some decent looking ones on special for $23, these are 1kg and have a solid metal mounting bracket and with a good metal catch and a metal body. don't get the ones with the crappy plastic clip (if you do replace this with a velcro strap instead)
When you mount it it should be within easy reach, you may want to have 2 installed, ie one in the front and one in the rear.
Don't get plastic ones, (scratch a bit off and use a magnet if you want to check), if you don't know how old your one is throw it out if its a cheap one or get it tested and checked, try out your old one so you know what it does when you need to use it.
