well the gf got me a sweet new air compressor for my bday (good catch she is) and now all i need to do is let the air out. how does evrybody do it? i have seen the tyre deflators on 4wdbits for $70. are they any good? how do you set the pressure you want, how long do they take? or should i just go round stick something in the valve and check with a pressure guage?
cheers Pete
tyre deflaters?
Stauns here too... fantastic. Mine are set for about 12PSI... although thats for Simexes. Normal mud-terrains I'd probably not go much below 20PSI for risk of rolling the tyre off the bead.
They take a while - around 10 minutes from memory to get the Simexes from 30 down to 12... although in all fairmess the local garages air pump takes that long to get them back to 30 again
Steve
Steve
