safari raise
safari_mulisha
safari raise
Post by safari_mulisha »
i went for a mission today to ind some vx cruiser springs to see how much longer than my standard springs they are
the fronts are 100mm longer than my safari fronts
my rears are 420mm long so now im after some 520mm long springs
any ideas?
doddzee
Is Doddgee
Post by doddzee »
I have a new pair of rear Dobinson springs which i bought as a set of 4 but only wanted the front They are 294lb/inch, with 530/550mm free height. $200
Will probly be a bit tall for what you need though. Those VX springs should give you about 3" Lift, the rears i have will give you at least 4".
4wdbits sells 60mm lift springs for the rear.
MWB V8 Safari Ute
safari_mulisha
i could be interested aye..
could just make an inch spacer in the lathe to even it out
i saw a vx cruise today with after market springs,shocks,drop boxes and spring spacers at the wreckers
Return to “Tool Shed”
