I had noticed over the last few months that on big climbs my temp gauge rose a little, not a lot, but it did get warm on big climbs.
I knew I had done a fair bit of mud holes etc through last winter and this summer.
I always made sure I sprayed PLENTY of water from the high pressure steam cleamer at work through the rads.
At times I even used an air gun to blow through it from the back.
I also sprayed water through with the fan running so as to help suck the water and dirt out of the core.
All this was good, and definitly helped keep it cleanISH!
Yesterday havning bugger all to do at work, I decided I would actually pull the rad out and give it a good clean. I did expect it to have a little amount of dirt in it, but not as much as it did.
Rear view
Front view
After about 45 mins, it was all fitted and back in. Of course, as its coming into winter, I refilled the cooling system with a good amount of anti freeze.
Totally worth the effort. And I totally recomend you all do it once a year.
