nah get it off the IFS model surf, say LN61 or 130...any of them really. get the pump and box with pipes and hoses etc, has the resivior mounted awat from the pump too so thats better.
basikly all you have to do is mount the box forward up on the outside of the chassis rail where it sits best,mount your pump (what engine are you running? )onto your motor,get a 60 or 70 series pitman arm and get a 60 or 70 series drag link to go from the box to the left side, hook it all up and your away
sounds so easy
it realy is that easy, the hardest bit is mounting the box,drilling holes and fitting crush tubes etc...takes a few hours
the box and pump on the 2f
