Also FJ40 drivers front guard
Wanted !!!!
- Armourguard
Wanted !!!!
Wanted 60 series powersteering box, sharfts and pump for conversion on FJ40.
"Owning a 40 is almost like having an ugly child, with a really good personality."
- Armourguard
- Armourguard
Armourguard wrote:Or Hilux Powersteering gearjust using for farm and light 4wding
if its not gonna be trying to turm massive wheels and only light to medium off road work i would sugest to use the surf power steering box, much much cheaper and way more of them around
- Armourguard
nah get it off the IFS model surf, say LN61 or 130...any of them really. get the pump and box with pipes and hoses etc, has the resivior mounted awat from the pump too so thats better.
basikly all you have to do is mount the box forward up on the outside of the chassis rail where it sits best,mount your pump (what engine are you running? )onto your motor,get a 60 or 70 series pitman arm and get a 60 or 70 series drag link to go from the box to the left side, hook it all up and your away
sounds so easy
it realy is that easy, the hardest bit is mounting the box,drilling holes and fitting crush tubes etc...takes a few hours
the box and pump on the 2f
- Armourguard
Thanks, im running a fully recond 2F
My wife had told me i had to get rid of it as i had to many toys until last weekend when she used it to drop one of the kids off at the neighbours (15kms away) now she says i cant get rid of it but it would be even better with P/S
im happy :groupjump:
What are you doing with your old 2F
