It was running real bad so I climbed under the bonnet and found a bit on the head that was meant to have a vacuum hose on it (I think its something to do with polution control), anyway I slapped a bit of hose on it with a screw in the end and it runs so much nicer.
With or without the hose the bloody thing just seems to stall whenever it feels like it. Its strange as it runs fine most of the time. The only thing I can put it down to is british engineering and wiring, but I need to fix the problem cos its inconvenient and frustrating.
It happened tonite when I got home from work. When in park it idles fine, but soon as I put it into gear it stalls. It then started running fine again and the revs haven't increased. It idles at about 750 in park and drops (normally) to about 500 once put into gear.
UPDATE: After spending most of my w/end under the bonnet playing around I have now got these results:
With the small hose I put on the drivers side tappet cover the vehicle seems to run real nice until it gets hot (about 15mins running), then it will stall ( or feels like it wants to stall) if I take my foot of the gas. Its as frustrating as all hell towing a trailor up scarborough hill (with a ton on the trailor) and getting to a tight bend just to have the car stall.
With the small hose off the car runs ruff, revs jump up and down all over the place.When its been running for some time I need to keep my foot on the gas or idle drops to a point where it stalls again, but it doesn't stall until I'm stopped with it idling. It stalls regardless of it being in or out of gear.
It looks like just turning the idle up would solve the problem, but I cant find any way to do this (give me back a carb
Any help/ideas
Regards Kelvyn.
