Hi, I have a surf powered by a 308 hodden, currently there are no flexi joints inthe system, and i have problems with gaskets sealing between the head and the manifold. I think flexi joints may help this, but I'm also wondering how sturdy they are, should i get some and weld em in?
Scottie
Exhaust manifold leaks
is the exhaust system rubber mounted or ridged to the body/chassis, if it is ridged to the body/chassis you will have problems all the time as the motor flexes on the engine mounts and strains against the rest of the pipe
or as pinky says,warped manifold face, get it planed/milled flat,new gasket,bolt it up with some maniseal,then fit slip clamp which it should have from block/bellhousing of motor to hold the pipe firm,if it doesnt have clamps then this will also make your problem worse
flexi pipe does help reduce the flex and vibration transfer through to the manifold from the rest of the system and are a good thing to have,but on an old holden motor... i dont think a little bit of extra vibration is gonna hurt it.if your gonna put flexi pipe in, put 1 short piece on each drop pipe just before the collector/balance tube, this will reduce vibration/flex transfer thru to the manifold.....
my 5c... probably just said a whole bunch of shit you allready knew
...hehhe ahh well,, at least my typing is getting better
clamp
should have clamps on the bell housing or block to hold that piece of pipe ridged to the manifold so no flex occurs there, but be rubber mounted from there back... if that makes sense
