this is my last option before getting prices and buying new ones.....
wanted...leaf springs...
does anyone out there have any good standard 413 leaf springs they want to part with? or even a second hand set of lift springs??
Not sure if you have got this sorted out already, but this info might help someone out there anyway.... For the rear you can just get a set off the back of an st90 van (the old, leaf model suzuki carry) - they bolt in for about a 2" lift or you can pull leaves from them to jack the front springs up if you need to. these usually aren't too hard to find and are a bit more heavy duty than the original 413 springs but don't ride too bad.
