Nissan Safari - Wrecking
Have a 1988 Nissan Safari SWB that I'm wrecking out due to failing WOF from rust in body. Is TD42 engine with auto, poo brown interior etc.
Keeping engine, diffs, indicators, grill etc for myself but everything else can go.
Front guards - LH v. good cond except for minor crease up by front indicator. RH straight, but bit of rust up by bonnet hinge. $75 each.
Bonnet - good cond. $75.
Doors - Manual window, westcoaster style mirrors. good cond. $75 each.
Full interior - drivers seat pretty tatty though.
Front bar - alloy jobbie
Glass - windscreen and side windows.
Fuel tank - 95L
Lots of other crap that I can't think of.
Have another one turning up soon, so need to get rid of it. Don't have access to Net like I used to, so best to call A/H on 027 392 1296.
Mitch
Fuel tank - 95L
Mitch
safari speedo
hello mitch
we spoke on the phone some months ago, have u got a safari speedo cluster complete??,thanks vince
Re: safari speedo
PigFmr wrote:hello mitch
Hi Vince,
Speedo doesn't work unfortunately (rev counter, voltage, oil press. etc all fine though). Solder circuit on back has a few cracks across it. Will see what this other one is like when it turns up.
Mitch
- safari_mulisha
safari_mulisha wrote:right hand side plastic seat side thing on the passenger front seat?
Yup, got one of them.
safari_mulisha wrote:glove box?
Yup, and one of them too.
safari_mulisha wrote:that lil bash plate infront on the front chassis x bar i ripped mine off
Not sure about that. Will have a look when I'm out at the ranch later in the week.
Re: safari speedo
GQTROL wrote:PigFmr wrote:hello mitch
Hi Vince,
Mitch
cheers mitch here from ya soon
vince
- safari_mulisha
- RoloverRover
- Driver/Navigator
Handbrake wrote:Hi. We need a Left front seat belt, retractable. Failed a bloody warrent cos they found a tiny sort of nick in it. Have you got one? Cheers.
Yup, sure do. What colour interior is it? Poo brown or grey? I've got one of each truck so should have it covered, just need to check on their condition first.
- Handbrake
- Black Pudding
GQTROL wrote:Handbrake wrote:Hi. We need a Left front seat belt, retractable. Failed a bloody warrent cos they found a tiny sort of nick in it. Have you got one? Cheers.
Yay! It is grey interior. Let us know what you want for it. Cheers
Handbrake wrote:GQTROL wrote:Handbrake wrote:Hi. We need a Left front seat belt, retractable. Failed a bloody warrent cos they found a tiny sort of nick in it. Have you got one? Cheers.
LWB or SWB? The grey one is from LWB, while the brown one is from SWB. They are different as the SWB goes into a recess in the B-pillar, but the LWB doesn't.
If its a shorty you've got, you may have to make do with a brown one.
- mroffroader
mroffroader wrote:Hey I need a tie rod or at least the two tie rod ends.......
Sorry, tie rod is staying with the diff and going to a new home.
Individual tie rod ends are available from Nissan. Use the female ones for a ute and a length of 4140 threaded accordingly. I've posted the part numbers here previously.
