chch 4wd area's for a keen newbie
rangimotors
Post by rangimotors »
Hi guys im a local in chch and only new to the offroad stuff i have a 93 surf pretty much stock (for the moment) with a set of 32 inch mud's looking for idea on missions to gain a bit of experiance, no point on putting all the gear on my truck before i even learn how to drive it...
Dunga
Post by Dunga »
welcome fellow newbie :lol:
89 lwb patrol, Mud comes standard
hiriklux
Post by hiriklux »
:idea: :idea: :idea: try the training day
PR
In the crap again
Post by PR »
(021) 02388443
Goose
Complete Plonker
Post by Goose »
Hi, welcome aboard :wink:
If you're looking for a place to go and play, there's a good 4wd area at the waimak that's quite good for testing/getting used to your truck. It's on the north side, about 1K or so past the motocross area. Keep following the "main" track from the boat ramp, past the motox area, then look for a left turn that almost doubles back, then goes to the right (like a big "S"). There's a nice playground where you can have some pretty safe fun 8)
Just make sure you have the means to get towed out, because there's still a few bits where a more standard truck will get stuck!! :wink: Cant go past some towhooks and a snatch rope. As PR has mentioned(in other newbie posts), Rick at 4wd accessories in montreal st can sort it out for you if you're not that way inclined..... :D
"He who dies with the most toys wins!!"
nuts
Location: somewhere arround westcoast offroading usually
welcome
Post by nuts »
the only way 2 find out is get out there and do it :wink:
but just dont go alone :!: :!: :!: :!:
make sure u have @ least 1 capable other truck and opperator with u just incase :roll:
mke sure u got a rope and a decent block to place ya jack on if needed :!: :!: :!:
otherwise go have fun :twisted: :twisted: :twisted:
RJT
Post by RJT »
That's where i learned the basics of REAL DRIVING hehehe. Actually i did it on the south side (mcleans) 24 hours after picking the truck up! some nice wee tracks round there
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
gards
Post by gards »
welcome, you have got the four wheel drive track down the the north bank of the ashly river, entry is of the end of rossiters road
rangimotors
ok thanks heaps, surf has a set of 32 by 11.5 muds on it they are rubbing a little on front at hard lock would i be correct in thinking that its because of the factory wheels and a set of 15 by 8 white spokes would help me out? looking around for a nice suspension lift option for a bit more clearance,
pajeroboy
Post by pajeroboy »
welcum aboard
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
