which is better - body or suspension lift
any thoughts/comments would be appreciated :study:
nuts wrote:I AGREE 50MM BOBY LIFT BUT [size=18]100 MM SUSPENTION LIFT[/size]![]()
:bubble:
Smurf wrote:nuts wrote:I AGREE 50MM BOBY LIFT BUT [size=18]100 MM SUSPENTION LIFT[/size]![]()
:bubble:
Cmon Nuts, on a IFS Surf don't be mean!!!
You'll get 50mm out of the front suspension max. So a body lift will probably be beneficial too, depending why you need the height??
brianr70 wrote:Need to get more clearance on my LN130 surf.
which is better - body or suspension lift![]()
Petemcc wrote:with the same mods a swb nissan will beat your surf any day mainly due to the front solid axel as ifs dont flex. but it will generally cost you more to do it.
pete
Heath wrote:Did the body lift thing on my hilux and it required a cert because of the "modification to the body mounting". Yeah I argued it was just a block inserted between so I hadnt modified the mount but they argued that it was the method of mounting not just the steel on the frame. End of the day I also got the engine recerted (crap job and didnt pass when i went back for body lift and steering), bigger wheels and tyres, different seats and the steering spacer certed.
At the end of the day I could've argued the lift didnt need doing but I wouldnt like to argue against a lawyer for an insurance company or in a criminal / coroners court if the worst happened so just bit the bullet.
Best to just read the regs and get your own interpretation in writting from your Wof / Cert guy.
Heath
brianr70 wrote:went to local 'Fully Equipped" to find out how much they would charge for the suspension lift...wait for it.....$1800
