V8 missing at 2krpm
Disco-Blue
V8 missing at 2krpm
Post by Disco-Blue »
Ok my 3.5 EFI V8 is missing when the engine gets warm at around 2000rpm. I have replaced all of the below and still get the problem which is now really pissing me off after the money ive wasted trying to fix it, any ideas anyone?
Plugs
Leads
Coil
Dizzy Cap
About to do fuel filter
Have checked and cleaned rotor as well.
mercutio
Post by mercutio »
i was going to say ¨when i had my land rover V8 whenever i had problems i learnt the first thing to check is the points¨
then i noticed yours is efi
my 4wd is not a truck
wopass
Post by wopass »
its british..... :roll: im surprised it revs past 2k :P
sorry back to the problem at hand, check for a vacume leak or condensation in or near the conection plugs to coils,dizzy. efi and high voltage dont like wet or dirty terminals.
matwelli
Post by matwelli »
Does it miss at 2K and above , or only at 2k and clears itself higher up ?
Mathew - 021 441 043
Disco-Blue
matwelli wrote:Does it miss at 2K and above , or only at 2k and clears itself higher up ?
Clears itselfs higher up but then comes back around 2500 - 2800. Only does it on open road and not under load as in actually going off road.
lowbox
Post by lowbox »
IGNITION AMPLIFIER?
Rangielux
Post by Rangielux »
wopass wrote:its british..... :roll: im surprised it revs past 2k :P
hey hey, naughty boy :wink:
try and isolate which cyl it is (might narrow things down abit), yeah could be a vacuum leak. you've covered most of the spark side of things but lowbox has a point. The only other things I can think of quickly is a bad injector - dirty or faulty, broken valve spring? (unlikely but who knows)
interesting problem :?
matwelli
Post by matwelli »
The fact that it goes away, only happens under light load sort of rules out most of the answers so far (ie mechanical/electrical faults)
Only thoughts are that at 2K to 2K8 rpm, light load on the highway the engine computer will be running things fairly lean, easy for a misfire to take place esp if one injector is a bit gummy, you would not notice under load, but at very lean running with short injector opening times you would notice it.
Do you get the same prob if you free rev it in the driveway ?
If you do, get a mate to hold the throttle at the point that its missing, pull the injector plugs off one at a time, the Cylinder that is missing will have no change when you pull the plug off, pulling it off any of the working cylinders will make the engine change note and drop revs
91Rangie
Post by 91Rangie »
Have you laced the spark plug leads in the correct way?
I dont mean the firering order
With the EFI it is very important that they are as it will cause a misfire
Disco-Blue
91Rangie wrote:Have you laced the spark plug leads in the correct way?
Please explain what lacing means, sorry im not that technical. Also does not misfire when free revving. Am going to replace fuel filter as it probably needs it anyway. Am running 96 in it but could it just be shit petrol? I might try BP's 98 and seeing if it does it on that.
91Rangie
Post by 91Rangie »
From the service manual
Fitting H.T Leads
Ensure replacement H.T leads are correctly refitted as illustrated
Failure to observe this instruction may result in cross-firing between two
closely fitted leads which are consecutive in firing order.
Disco-Blue
Pretty sure I have done that but will double check just to be safe.
Disco-Blue
Ok have checked and all leads are in their rights places, I don't know what it could be and have been trying to solve this for the last 3 months so think I might just get rid of it.
billyvanboheman
Post by billyvanboheman »
Range Rover, Give ya 50 bucks for it :lol:
I'm sure theres lots that will disagree but sometimes its just better off ringing up the local guy that fixes those things and arange to drop it off in the morning and pick it up in the afternoon all running properly again :wink:
It sure beats all those hours spent in the shed late at night chasing your tail and getting nowhere and frustrated :x
Disco-Blue
billyvanboheman wrote:Range Rover, Give ya 50 bucks for it :lol:
Owch thats a cheap shot, talk about kicking somebody when there down :shock:
billyvanboheman
Disco-Blue wrote:Owch thats a cheap shot, talk about kicking somebody when there down :shock:
I couldn't help it, just way toooooo hard to resist :lol:
Don't despair, I'm sure you will get it, anyone on here work for or know of a mate that works for a Rangie dealer, they may have struck the problem before and be able to work it out from your description.
Stick with it, it will work out!!
Scott
Post by Scott »
I had a miss with my 1ggeu, turn out to be the water temp senser telling the ecu that the engine was cold thus over fueling and missing
Disco-Blue
Nah temp gauge works all good so don't think it could be sensor related. Think i'll just tidy it up, sell it and get something else thats not Land Rover.
Petemcc
Post by Petemcc »
dont give up on it jst yet. really you have only had one problem with it, and you have just replaced alot of bits that were probably about due to be replaced anyway and that you would replace on any new truck you got. take it to a landrover place and see what they think. it cant be anything to serious just a matter of eliminating things it isnt till you find it.
Pete
billyvanboheman
Are you in CHCH Disco-Blue?
Rangielux
Post by Rangielux »
Disco-Blue wrote:Nah temp gauge works all good so don't think it could be sensor related. Think i'll just tidy it up, sell it and get something else thats not Land Rover.
Ya never know it could be sensor related, more often than not the temp gauge sensor is separate from the ecm temp sensor.
If its overall a good vehicle and you like it still, keep it, sometimes its better the devil you know. It sounds like that $50 part replacement of some kind might fix it?
Sounds like you tried most things at a basic level (no offence) and spent a bit of money on parts already. Take it to a tuning specialist or someone who is an enthusiast rover dude or the Landie/rangie dealer (but sometimes they're not all that ethusiastic but very expensive :( )
Canty land rover owners club (if theres one) may have a contact for a good tech guy. - thats assuming you're down that way?
Steve_t647
Post by Steve_t647 »
Summit 4wd on Haseldean Rd do land and range rovers and they advertise on this site.
With the correct gear or experience it could be a 10 minute diagnosis.
I have no idea if you can get the computer panic and log info to a laptop or a display of some sort but being fuel injected the computer will be telling you something.
It was the one saving grace of running a link down the quarter, but link does not have enough fuel and ignition points for smooth road driving (250 rmp increments)
Good luck and they are a really good 4x4 when going well :oops: I just went for a Hilux to stop hireing trailers
Disco-Blue
Hmm will try summit 4wd as see if they can work it out, if not will sell it and buy something a little better nad cheaper to run.
Thanks for all your input guys!
JAMUBA
Post by JAMUBA »
Hi Dude
Is your tacho doing dodgy things, could be an alternator fault, follow this-http://www.rangerovers.net/repairdetails/altrebuild.htm
This site is gold for rover stuff, dont be put off by it being a range rover site, late 80's rrc run mostly the same running gear as a disco 1.
Chris
karmobRob
Stropper
Post by karmobRob »
Lucas alternators are notorious for bad diodes which can affect the ecu.
Disconnect alt or remove belt and give it a go.
ROBERT
Disco-Blue
Ok have had another play round with it today after finally getting some time to, i disconnected the water sensor as well as trying a piece of wire in each contact but the thing is still missing so it can't be the that.
Alistar from Summit4WD said he would take a look so will be going to see him, if your on here Alistar PM me a mobile number if you can please and I will txt you to find out when suits you.
karmobRob
Stropper
Post by karmobRob »
what was the final outcome Blue?
Disco-Blue
Sold it haha, bought a cruiser instead.
fweddy
Post by fweddy »
Disco-Blue wrote:Sold it haha, bought a cruiser instead.
Well well! Well done!
