wanted: Lift blocks for bj70
50mm lift blocks
what have ya got?
what have ya got?
Re: wanted: Lift blocks for bj70
basics wrote:50mm lift blocks
what have ya got?
I have a whole lot of surf lift blocks. They are 75mm but could be chopped down to 50mm
- safari_mulisha
- 4x4boy
turoa wrote:basics wrote:50mm lift blocks
what have ya got?
Hi Mate. I could be keen on those 75mm blocks. How many have you got (I need 10) and what do you want for them?
1991 Isuzu Mu - BUGGER Blew it up. Next> Landy Discovery - Sold (gone up to Wellington). - Landcruiser Prado - Bodylift, Snorkel, Tow Hooks, Simex Jungle Trekka 2's
4x4boy wrote:turoa wrote:basics wrote:50mm lift blocks
what have ya got?
There should be 10 on there. Ill check for you tommorow. As to price - make an offer but dont be stink about it as I have to remove them.
what have ya got?
are the rumors true?? have you had three trucks in about as many weeks??
p.r.a.d.o.
toymota thats stock standard.
- 4x4boy
kaney wrote:4x4boy wrote:turoa wrote:basics wrote:50mm lift blocks
what have ya got?
There could be some truth to it.. I'm onto my 3rd since the Disco but I think I might settle for this one. Starting the mods now.
p.r.a.d.o.
what have ya got?
Yes, there are 10 blocks there
- 4x4boy
I was in getting bolts at Blacks in Chch yesterday and was quoted $16.32 + GST for a 250mm length of Nylon rod to use for blocks. Cheap as I reckon. As long as you can split it yourself I doubt you will find cheaper.
- 4x4boy
I've always used the Nylon blocks and its never given me any trouble.
I guess if you were doing something like a Safri the weighs a tonne then the acetol blocks would be better. They have thaty as well though. Prob slightly more expensive.
- safari_mulisha
acetal wood not be the best option, nylon will swell and is very rigid so its not that flash either, the UHMWPE is the stuff we sell to 4wd upgrades.
Your car Your choice, im just telling what wot i would recomend, i have been selling the stuff for a couple of years now, not saying i know better or anything. just informing ya thats all.
its 60mm dia so weight wont be a problem.
Doby -
http://www.trademe.co.nz/Trade-Me-Motor ... 74.htm?p=2
This bloke sent me 2 x bloks to my dimensions, and 4x u-bolts to my dimensions. $78.00 on my doorstep.
Workmanship was great and the desired measurements were spot on.
but of course you be wanting them for coils not leaf springs........ me dumb......... ignore the above.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
xj wrote:Doby -
isnt this thread about body lift blocks? :scratch:
I went to Ludoplas in penrose and got 8 35mm high 60mm dia UHMWPE blocks cut. It cost me honestly $28. got all the bolts from blacks fasteners for $12 with 75% discount cos they thought i was important
. The as cut blocks were within 1mm.
I had to drill them though, and I havent got it certed yet so best take advice from some others who used same material and got cert.
Ohh yeah, watch the fan shroud.. real pain in the ass on mine, also my handbrake cable went kinked and my electric hub lines a bit short cos also did a 2 inch spring lift. and just found out today it keeps popping out of low ratio. more fun
So much for a 3 hour job... took a whole weekend and now i have gear lever fun
No one else seems to have these problems....
- 4x4boy
xorph wrote:I went to Ludoplas in penrose and got 8 35mm high 60mm dia UHMWPE blocks cut. It cost me honestly $28. got all the bolts from blacks fasteners for $12 with 75% discount cos they thought i was important. The as cut blocks were within 1mm.
Ohh yeah, watch the fan shroud.. real pain in the ass on mine, also my handbrake cable went kinked and my electric hub lines a bit short cos also did a 2 inch spring lift. and just found out today it keeps popping out of low ratio. more fun![]()
So much for a 3 hour job... took a whole weekend and now i have gear lever funNo one else seems to have these problems....
I've done lifts on a couple of trucks and rest assured that all these problems are standard stuff. All easy fixable though eh.
4wdnuts wrote:xj wrote:Doby -
lol...... erm yeah it is.... like i said, ignore the above.
In fact..... ill just shut the fuk up.....
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
