it was standard on 31s and had no winch
me and a mate put a 5inch api pipe on the front to save my grill untill i got a winch i allso installed a 50mm body lift
so even pigs can fly but i didnt want it to fly i wanted it to smash thru the bush and get me through the biggest bogs
after all this playing around getting stuck was frustrating me so i fitted a winch which has saved me and a few mates
now i needed more traction i put the task to 34x10.5 simex jungle treckers
which i allso had to cut my gaurds to fit
with the bigger tyres i was down on power so last week i fitted an hx35 digger turbo i run less that 15psi usually around 10 depending on load
so shes just about a bulldozer i will keep you posted to my progress next will prob be a spring lift or bars
