V8 missing at 2krpm
- Disco-Blue
V8 missing at 2krpm
Ok my 3.5 EFI V8 is missing when the engine gets warm at around 2000rpm. I have replaced all of the below and still get the problem which is now really pissing me off after the money ive wasted trying to fix it, any ideas anyone?
Plugs
Leads
Coil
Dizzy Cap
About to do fuel filter
Have checked and cleaned rotor as well.
Plugs
Leads
Coil
Dizzy Cap
i was going to say ¨when i had my land rover V8 whenever i had problems i learnt the first thing to check is the points¨
then i noticed yours is efi
my 4wd is not a truck
- Disco-Blue
wopass wrote:its british.....im surprised it revs past 2k
hey hey, naughty boy
try and isolate which cyl it is (might narrow things down abit), yeah could be a vacuum leak. you've covered most of the spark side of things but lowbox has a point. The only other things I can think of quickly is a bad injector - dirty or faulty, broken valve spring? (unlikely but who knows)
interesting problem
The fact that it goes away, only happens under light load sort of rules out most of the answers so far (ie mechanical/electrical faults)
Only thoughts are that at 2K to 2K8 rpm, light load on the highway the engine computer will be running things fairly lean, easy for a misfire to take place esp if one injector is a bit gummy, you would not notice under load, but at very lean running with short injector opening times you would notice it.
Do you get the same prob if you free rev it in the driveway ?
If you do, get a mate to hold the throttle at the point that its missing, pull the injector plugs off one at a time, the Cylinder that is missing will have no change when you pull the plug off, pulling it off any of the working cylinders will make the engine change note and drop revs
Mathew - 021 441 043
- Disco-Blue
91Rangie wrote:Have you laced the spark plug leads in the correct way?
I dont mean the firering order
With the EFI it is very important that they are as it will cause a misfire
Please explain what lacing means, sorry im not that technical. Also does not misfire when free revving. Am going to replace fuel filter as it probably needs it anyway. Am running 96 in it but could it just be shit petrol? I might try BP's 98 and seeing if it does it on that.
- Disco-Blue
- Disco-Blue
- billyvanboheman
- Sadam_Husain
- Angry bird
I'm sure theres lots that will disagree but sometimes its just better off ringing up the local guy that fixes those things and arange to drop it off in the morning and pick it up in the afternoon all running properly again
It sure beats all those hours spent in the shed late at night chasing your tail and getting nowhere and frustrated
- Disco-Blue
- billyvanboheman
Disco-Blue wrote:Owch thats a cheap shot, talk about kicking somebody when there down
I couldn't help it, just way toooooo hard to resist
Don't despair, I'm sure you will get it, anyone on here work for or know of a mate that works for a Rangie dealer, they may have struck the problem before and be able to work it out from your description.
Stick with it, it will work out!!
- Disco-Blue
dont give up on it jst yet. really you have only had one problem with it, and you have just replaced alot of bits that were probably about due to be replaced anyway and that you would replace on any new truck you got. take it to a landrover place and see what they think. it cant be anything to serious just a matter of eliminating things it isnt till you find it.
Pete
Pete
- billyvanboheman
Disco-Blue wrote:Nah temp gauge works all good so don't think it could be sensor related. Think i'll just tidy it up, sell it and get something else thats not Land Rover.
Ya never know it could be sensor related, more often than not the temp gauge sensor is separate from the ecm temp sensor.
If its overall a good vehicle and you like it still, keep it, sometimes its better the devil you know. It sounds like that $50 part replacement of some kind might fix it?
Sounds like you tried most things at a basic level (no offence) and spent a bit of money on parts already. Take it to a tuning specialist or someone who is an enthusiast rover dude or the Landie/rangie dealer (but sometimes they're not all that ethusiastic but very expensive
Canty land rover owners club (if theres one) may have a contact for a good tech guy. - thats assuming you're down that way?
- Steve_t647
Summit 4wd on Haseldean Rd do land and range rovers and they advertise on this site.
With the correct gear or experience it could be a 10 minute diagnosis.
I have no idea if you can get the computer panic and log info to a laptop or a display of some sort but being fuel injected the computer will be telling you something.
It was the one saving grace of running a link down the quarter, but link does not have enough fuel and ignition points for smooth road driving (250 rmp increments)
Good luck and they are a really good 4x4 when going well
I just went for a Hilux to stop hireing trailers
- Disco-Blue
- Disco-Blue
Ok have had another play round with it today after finally getting some time to, i disconnected the water sensor as well as trying a piece of wire in each contact but the thing is still missing so it can't be the that.
Alistar from Summit4WD said he would take a look so will be going to see him, if your on here Alistar PM me a mobile number if you can please and I will txt you to find out when suits you.
- Disco-Blue
