body lift help
basics
body lift help
Post by basics »
how do you get to the bolt at the rear of the truck?
Aaron
Post by Aaron »
I am taking a stab in the dark, but probably a tube socket in the hole. :)
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
Aaron wrote:I am taking a stab in the dark, but probably a tube socket in the hole. :)
If the bolts down that hole where I think it is then yep as Aaron said :thumright:
basics
Post by basics »
the bolt and the hole dont line up, i thought maybe im missing sothing obvious(SP)
ill keep trying then
I'd expect the bolt to be installed from the top and the nut underneath? If so can you see how they got the bolt down the hole?
I only had the front 6 mounts to do with a cab/chassis so I don't know how they did them that far back :?
xj
Post by xj »
gas ax cuz :shock:
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
How did the body lift go :?:
:idea: Did you work out how to get to the rear bolts?
basics
Post by basics »
Sadam_Husain wrote:How did the body lift go :?:
if i didnt have bad luck id have no luck at all. the bolts were only just too small.
might have to wait till monday, been my dd i had to put her all back together again.
xorph
Post by xorph »
Hey how did your body lift go?
Im doing the exact same thing at the moment on a 96 70 series.
-My vote for the most horrible vehicle to work on of all time, partially due to the anti-anti-sieze compound toyota thought was fun to use on the newer models....
2 hours later and ive finished drilling out my first bolt......
Did you find you had trouble with the handbrake cable being too short?
just wondering how others have got round this if it proves to be a problem. (doing a 40mm body lift, allready 50mm susp lift)
Also: :evil: a pox on anyone who says they can do a body lift in 2hrs! can see this taking me the next 4 nights.
body lift
fond out allbody lifts have to be certafide
xorph
Post by xorph »
makes sense, potential for things to go horribly wrong.
do you know a cheap cert place in Auckland?
xorph wrote:2 hours later and ive finished drilling out my first bolt......
He got his body lift all sorted before the rallywoods trip at QB weekend :P
Didn't have any trouble with the handbrake cable on my 70 series but it's almost 20 years older than yours and a cab/chassis so I dont know if the handbrake is different. I only had 6 bolts and it only me about 1.5-2Hr's.
Got to watch the wiring loom, brake lines were ok, fuel tank was suspended from the cab so the filler neck was ok, released the clamp on the steering shaft to let that slide out 1-2mm and had to lower the radiator shroud and I think that was about it :wink:
wopass
Post by wopass »
i may be wrong but this is a cruiser ? if so it probably has a captured nut on the top and the bolt goes up from underneath :wink:
wopass
Post by wopass »
xorph wrote:Hey how did your body lift go?
i can do a body lift in 2 hours :wink: ...... if it all goes well 8)
xorph
Post by xorph »
Zounds! A pox bethroweth upon thee!
wopass
Post by wopass »
xorph wrote:Zounds! A pox bethroweth upon thee!
hehheheh :lol:
body lift
no not yet haven't need one yet
xorph
Post by xorph »
To finally answer this poor mans question:
Use Toyota SST #13: a 3/8 14mm socket with flexible powerbar (i.e the type that pivots near the end) and a stillson wrench to stop it trying to turn and mangalate everything.
so you've got it all sussed now :wink:
xorph
Post by xorph »
doom....
cant find no M10 x 180mm bolts.
xorph wrote:doom....
can get them through your nearest steel and tube (grade 8.8 )
part number 10180ZHT $2.97 plus GST :thumright:
No I don't know the part numbers off my head I had a look at the receipt I got when I brought my bolts :wink:
wopass
Post by wopass »
this guy is GOOD ! !
xorph
Post by xorph »
Madas Sadam!
keep this up and we'll forget about those war crimes
the accountant makes me keep all the work related... um and cruiser receipts neatly filed away to keep the books all in order for the tax man :wink:
Bubba
Post by Bubba »
Sadam_Husain wrote:the accountant makes me keep all the work related... um and cruiser receipts neatly filed away to keep the books all in order for the tax man :wink:
As Toyota Corolla repairs??
Benjamin Franklin
Return to “Toyota”
