hi lux power
hi lux power
has any1 got any idea how to gain bit of power without to much expense...it is a 95 sr5 double cab,32 inch wheels,4.8 diff gears,2.8 turbo (turbo off 2.4),goes ok but feel like needs bit more for hills and things on road
hilux power
yeah got big exhaust and been playing with injector pump but not sure how much to play with it without damaging something,i dont know but maybe expecting too much from it
2.4t more power
I have a LN130 fitted with a 2.4 turbo, I have fitted 3 washers on both bolts in between the relief valve on the turbo. I use my vehicle for towing and it runs alot better. it is however your call whether you do this. The only problem I have is when you rev it out to much the boast light goes from green to red, but otherwise no other difference is felt. the light resets itself after you switch off an restart. I have been running my wagon like this now for 4 months.
- Sadam_Husain
- Angry bird
Re: 2.4t more power
That boost warning light is there for a reason... you're overboosting the engine, which can have catastrophic effects. Especially on an engine that is widely recognised as being mechanically weak. I certainly wouldn't recommend doing what you're doing - however I understand how tempting it is to get more power and how hard it would be to go back now you've had it
As for a 2.8TD - thats about as good as it gets in the L-series engines... I can't think of anything else that will make any difference... your next step is really going to be a repower - a 1KZ would be a noticeable huge improvement in the diesel arena, or you're looking down the barrel of a petrol-sucker like a 1-or 2JZ or an older supra swap or maybe a 1UZ lexus V8 swap.
Any of those swaps is going to cost you tho... unless you have a spare $5k I'd get used to the 2.8TD
Steve
Steve
Hongi wrote:I have a LN130 fitted with a 2.4 turbo, I have fitted 3 washers on both bolts in between the relief valve on the turbo. I use my vehicle for towing and it runs alot better. it is however your call whether you do this. The only problem I have is when you rev it out to much the boast light goes from green to red, but otherwise no other difference is felt. the light resets itself after you switch off an restart. I have been running my wagon like this now for 4 months.
- Steve_t647
Diesel performance engines are only in their infancy, previously they were in Big Heavy trucks and were all about torque, the technology on them is so old they can still run on vegatable oil and old fish and chip oil and if you press enough peanuts peanut oil.
The newer diesel turbo's out of europe and Japan are far more complex and are much harder to get to run on anything other than pump diesel, this is because they have looked at the technology and tuned things better, if you want more power relyably then you need to do an engine swap, and most likley to a petrol. Sorry
Case in point the 1.8 Turbo VW Diesel out perform's the 2.4 turbo diesel toyota built, as for where fuel will end up I think Ethanol will be the answer we end up with as the petrol technology will not have to change much only the timing, rubber seals and quantities.
BTW the brand spanking new twin turbo V8 diesel in the new Landcruiser is pretty impressive but the cost of these new beasts and they are thirsty.
- Steve_t647
