Does anyone have a car trailer in welly???
mroffroader
Post by mroffroader »
I need to borrow a car trailer for queens birthday weekend that will fit the nisco on it... anybody have one or know where i can borrow one :cry:
Ryan
Post by Ryan »
is it not legal??
mroffroader
Ryan wrote:is it not legal??
it is but it wont go over 20km/ph before the front wheels and steering wheel start shaking violently :cry:
mroffroader
cloggy is kindly lending me his trailer for the weekend.....hopefully it fits on there :roll: :D
warlord225
Post by warlord225 »
do you want me to hook you up with some balancing?
mroffroader
Haha, I work at Naenae tyre court on saturdays so i'll get it done there. Cheers anyway :wink:
Bubba
Post by Bubba »
Is it a big problem to fix James?
Benjamin Franklin
lilpigzuk
Tiger Balm
Post by lilpigzuk »
you checked the castor?? may not have enough??
turoa
Pyro Junior
Post by turoa »
lilpigzuk wrote:you checked the castor?? may not have enough??
Castor is fine as we have put big ass castor plates on. I think the problem may be that james was too cheap to buy a new panhard bush.
mroffroader
could be a number of things,
-panhard bush
-tie rod end?
-wheel alighnment out of whack
-steering rod ends?
-also doesnt have a steering dampner on it :roll:
turoa
Pyro Junior
Post by turoa »
-panhard bush
-tie rod end?
-steering rod ends?
Steering dampner shouldnt really make a difference if we have castor right. All the ends were all fine?
You should try and get a panhard bush during the week and replace it and see if it makes a difference.
+ the bar needs to go back on
+ you owe me a tie rod end :roll:
mroffroader
-panhard bush
-tie rod end?
-steering rod ends?
what are nissan panhard bushes worth???
yea i no about the bar
tie rod end = :oops:
I drove one of my old FJ40s without a steering damper once
.... it was F**ING SCARY :shock:
mroffroader
Sadam_Husain wrote:I drove one of my old FJ40s without a steering damper once
what did it do????
I didnt shudder but it was all over the road and hard to keep in a straight line for more than about 2 seconds at a time
mroffroader
Sadam_Husain wrote:I didnt shudder but it was all over the road and hard to keep in a straight line for more than about 2 seconds at a time
:shock:
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
You should take a good hard look at the swivel bearing preload. If the castor is correct then there will be a high possibilty this is the problem.
doddzee
Is Doddgee
Post by doddzee »
You may want to measure the width of your disco now your running the gq's to see if its going to fit, my saf is 2030mm (but has 13.5" tyres) wide and car trailers that arent usually over 2000 wide.
How many shims are in the swivel bearings?
Is it a nissan panhard bush that is worn?? I have one you could try.
MWB V8 Safari Ute
mroffroader
yea nissan panhhard bush thats worn.....what time are you at home 2moro arvo jared il come up and pick it up off you..... :?: :D
mroffroader
doddzee wrote:You may want to measure the width of your disco now your running the gq's to see if its going to fit, my saf is 2030mm (but has 13.5" tyres) wide and car trailers that arent usually over 2000 wide.
it wont fit in its current state. as i have 11.5" wide simex's and -25 offset rims. but i have borrowed some standard alloys and 29" nissan rims and tyres off marty so should fit with them on it :D
If it needs to be towed out to rallywoods are we going to have to tow it round rallywoods? :oops:
Just kidding..... :lol: Should be interesting to see it in action finally :lol:
doddzee
Is Doddgee
Post by doddzee »
mroffroader wrote:yea nissan panhhard bush thats worn.....what time are you at home 2moro arvo jared il come up and pick it up off you..... :?: :D
Ill be home about 6, note that its just a loaner, you are not keeping it!! :wink:
MWB V8 Safari Ute
