solid front diff stiff as suspension, no ground clearance small feet. being turned into a mud eating monster.
waste of time modifying you may say? well its mine and i'll make it as big and as bad as i can afford to at the mo
list of mod's so far.
31" pirelli scorpions or 750 michallin X's depends on the day to what i'll use
hilux rear springs with 3 leaves removed all round
long shocks in the front
3'' longer shackles
flipped steering set up
custom $40 pvc snorkle
moved diffs
front forward 2-3"
back backwards 2-3"
attitude to boot
still to come
longer drive shafts
longer brake lines
cut gaurds
rear to be cut off and turned into a proper well deck (be a few years away.
winch
roll cage
more attitude to boot
standard
new shackle
