porno for psi junkies
adventures_more
Post by adventures_more »
how do you find your Jungle trekkers ? what size & how much were they ? look like an incredibley tough tyre - looks like the nato unimog pattern !
safari_mulisha
Post by safari_mulisha »
they go hard
throw alot of mud around they pull u along instead of dig you in
i havnt got any pics of others i have done
steam pipe is just seamless hydrolic pipe its really tough
diesel manifolds are very simple they breath alot
i cruise at 100k boosting 3 psi
decsnz
turbo manifolds
Post by decsnz »
Hi I'm new to this forum.
I am looking to turbo my safari and found an interesting page on making turbo manifolds.
http://www.sdsefi.com/techheader.htm
Just a question?
Can I use an exhaust gasket as a template for making a manifold?
safari_mulisha
you can but i wouldnt garentee a fit first time
what it did was vice grip the manifold to the 10mm flat section and spray paint directly into the holes then drilled them out
bolt the gasket and the manifold on the draw around the gasket unblot it again and mark out the port holes
gas axe and die grind them out
easy as
decsnz
Post by decsnz »
Hmmm, I was sort of hoping I didn't have to unbolt the manifold until I was ready with the new setup. Oh well
tgaguy1
Post by tgaguy1 »
Hey decsnz dont forget to photograph and post the conversion on here for all the other Nissan owners to get inspiration from.
decsnz
Post by decsnz »
Problem solved. I have got a water cut manifold flange from A1 Exhaust in Glenfield.
safari_mulisha
yeah thats the way to go
i gas axed mine out
how much was it to water jet it?
decsnz
Post by decsnz »
About $75 for the steel and cutting. I will let you know when I pick it up.
