Shear pin is broken on my PTO. (factory cruiser)
What is the shear rating for these, I've been recommended to drill it a little larger, and also some one suggested a bolt (LT) and take a few spares.
Might sound silly, but what is the shear strength on a galv 4" nail? esp as opposed to something else the same diameter?
4" Shear Strength
pto
it could be any where between 1 ton to 12 tons , stock pins are underateded to save the rest of the pto system from damage , if it broke you should of used a share block to reduce the load on your winch, you go high share rate the rest of the winch could suffer
Re: pto
coxsy wrote:it could be any where between 1 ton to 12 tons , stock pins are underateded to save the rest of the pto system from damage , if it broke you should of used a share block to reduce the load on your winch, you go high share rate the rest of the winch could suffer
Pin was gone when I bought truck
Was thinking the nail would work as a temp measure for the weekend as would be lower shear strain than a std shear pin or LT bolt recommended by cruiser specialist - but may be mistaken?
I run a 8mm low tensile bolt (grade 4.6) in the front of mt pto shaft (easy to get at in the middle of a mud puddle) and a higher tensile bolt in the rear postion (grade 8.
the theory is (and has worked so far) that the lower tensile bolt will shear first. I can get to it easily to change it out. I have loaded the pto system many times with this configuration and it seems fine. The low tensile bolt shears at about the same or just a bit more than the nissan shear pin.
