body lift help
body lift help
how do you get to the bolt at the rear of the truck?
- Sadam_Husain
- Angry bird
- Sadam_Husain
- Angry bird
- Sadam_Husain
- Angry bird
Hey how did your body lift go?
Im doing the exact same thing at the moment on a 96 70 series.
-My vote for the most horrible vehicle to work on of all time, partially due to the anti-anti-sieze compound toyota thought was fun to use on the newer models....
2 hours later and ive finished drilling out my first bolt......
Did you find you had trouble with the handbrake cable being too short?
just wondering how others have got round this if it proves to be a problem. (doing a 40mm body lift, allready 50mm susp lift)
Also:
a pox on anyone who says they can do a body lift in 2hrs! can see this taking me the next 4 nights.
Also:
- Sadam_Husain
- Angry bird
xorph wrote:2 hours later and ive finished drilling out my first bolt......
Also:a pox on anyone who says they can do a body lift in 2hrs! can see this taking me the next 4 nights.
He got his body lift all sorted before the rallywoods trip at QB weekend
Didn't have any trouble with the handbrake cable on my 70 series but it's almost 20 years older than yours and a cab/chassis so I dont know if the handbrake is different. I only had 6 bolts and it only me about 1.5-2Hr's.
Got to watch the wiring loom, brake lines were ok, fuel tank was suspended from the cab so the filler neck was ok, released the clamp on the steering shaft to let that slide out 1-2mm and had to lower the radiator shroud and I think that was about it
xorph wrote:Hey how did your body lift go?
i can do a body lift in 2 hours
- Sadam_Husain
- Angry bird
- Sadam_Husain
- Angry bird
Sadam_Husain wrote:xorph wrote:doom....
cant find no M10 x 180mm bolts.
can get them through your nearest steel and tube (grade 8.8 )
part number 10180ZHT $2.97 plus GST :thumright:
No I don't know the part numbers off my head I had a look at the receipt I got when I brought my bolts
this guy is GOOD ! !
- Sadam_Husain
- Angry bird
