was wondering if a similar thing would work with diesel what say you guys is my idea totally outlandish
is this a silly idea
my ex flatmate had a commodore that was supercharged and he injected LPG directly into the intake manifold as a liquid which cooled his intake temperature tremendously.
my 4wd is not a truck
Do a quick search on Google, there is quite a bit of info on LPG/CNG injected Diesel engines. As coxsy said, it increases the power significantly and boost fuel economy to some pretty amazing levels if not using the increased power. The trick is getting the mixture just right, too much and it will destroy the engine.
Our local power supply company had Bedford diesel trucks in the early 80's running on a CNG / Diesel mixture.
You mean http://www.gastec.co.nz/ I assume.
sure have
worked wounders on my 1996 Nissan Mistral couldnt belive the power increase was awwwsummmmmmmmmmmmm but the trick is to have the lpg shut off while on idle or it runs like a petrol with the choke out gezzzzzz Bob i still got 18 months b4 mine is outta warrenty
Re: sure have
long wrote:worked wounders on my 1996 Nissan Mistral couldnt belive the power increase was awwwsummmmmmmmmmmmm but the trick is to have the lpg shut off while on idle or it runs like a petrol with the choke out gezzzzzz Bob i still got 18 months b4 mine is outta warrenty
is yours turbo or NA
yup
yeh it was turbo but i no longer own it i saw the light n brough a ssangyoung only thing wrong with it is the warrentee being on it like bob i cant do stuff all to this one but im gonna go all out on my terrano
Re: yup
long wrote:yeh it was turbo but i no longer own it i saw the light n brough a ssangyoung only thing wrong with it is the warrentee being on it like bob i cant do stuff all to this one but im gonna go all out on my terrano
hey if you ever roll it iĺl buy the egine
Re: sure have
Did you piece your fumigation kit from bits here in NZ or did you buy a comerically available kit? How much did it cost to do?
i used
i used a regulater that on my L300 van it was suitable for 1000cc - 2000cc i screwed the power valve rite in and very very slowly opened it up untill i could not see any more dark diesel smoke out the back of my Mistral i put a micro switch on the throtal stop on the injector pump so that it would shut off the lpg at an idle and would turn on again when you had your foot down about 25 mm by then you had a few revs on and it felt as though a high powered cam had turned on such is the gain in power
- Moriarty
Jeff, I am off into the bush with mates from the 7th until the 14th this month. Then I am gonna take a wee wander up to Manaia, have the kettle on and tea in the pot!! I am gonna gaze apon your craftiness and see if I can do it to my 2Dragon-wagon, bugger waiting for the warranty........
saw a kiddi-pic that was totally forgettable the other day, but had huskies and malamutes in it, I can see why you play with dawgs now!!! (girls ARE better though)
- Moriarty
Re: yup
you wanta put your name in for the Pureora trip?
wanta see this LPG gizmo in action, I am not gonna wait for warrantee to run out, I am gonna do it!!
but
Bob I dont own the Mistral no more it was the one i had the LPG fogging on not the ssangyung um the trip is it ok 4 a shiny ?
- Moriarty
Re: but
long wrote:Bob I dont own the Mistral no more it was the one i had the LPG fogging on not the ssangyung um the trip is it ok 4 a shiny ?
all grades from gravel road exploring to sand all the paint off and new panels when you get home!!
Seriously, it IS all grades, you choose how tough you wanta make it.
Pureora is a large area, we havent yet explored it all. We are going to have enuff vehicles to have two groups, one playing in the muddy stuff, and one group exploring and looking around.
as regards the Menstrual, That is no matter, you DID the fumigation, and remember how and what you did that's all that matters.
Hope to see you before Labour weekend anyway, to talk about the LPG.
M.
