lockright diffs
lockright diffs
How hard are these to fit ,will be goin in a ln60 hilux, also if put in the front do they make the truck hard to steer on hard ground
- IcedJohnno
- Trailer Trash
I have one in the front of my 71 series Prado, and have found no difficulties with steering on hard ground. I am still running 31 BFG MT's though. Do you have power steering? I do so perhaps this makes a difference. Others have commented on this before, Wopass I think.
Hey Wopass has your steering got easier with the Lock-Rights now you have changed power steer pumps and boxes?
Mine definitely took longer than 2 1/2 hrs, probably 8 by the time I got the electric hubs sorted but I was changing it whilst off work for six months after dislocating my shoulder badly
That’s dangerous forms of motorsport for ya
a lockright in the front can cause nothing but problems depending how hard you intend to pedal your truck and your tyre size etc. trust me i know from expeirence!
- hosehustler
front locker,makes the steering stiffer,provides unbelievable traction,smashes cv'sand sometimes makes turning tight corners in the slippery mud more diffacult.rear lockers are cool gives you positive traction when you want/need it and still able to turn corners without scuffing tyres as it will slip on good traction surfaces.
rear locker.....do it they rule.
front locker.... get longfields..then do it, they rule more (or go arb if you can afford to blow the money)
thats my 6c
thats my 6c
- hosehustler
