I need to replace my battery. I don't have a winch yet, but it should be coming soon after. Space is limited in the engine bay so some of the larger truck batteries (like Endurant IDC31DT) are out of the question. Out of Optima and Orbital, which one would you recommend?
Also where is the best place to buy them at the least cost? Name of the place would be helpful.
Thanks.
Which battery???????
- Sadam_Husain
- Angry bird
Re: Which battery???????
TJ wrote:I need to replace my battery. I don't have a winch yet, but it should be coming soon after. Space is limited in the engine bay so some of the larger truck batteries (like Endurant IDC31DT) are out of the question. Out of Optima and Orbital, which one would you recommend?
Thanks.
If space is limited, then definately look at the Optima gel range (red top, yellow top etc). For a given CCA rating, they are physically 10-15% smaller than a conventional lead/acid battery.
