Go cart/mechanical type caliper for disc t-case handbrake?
brakes-shocks-lockers-etc
turoa
Pyro Junior
Post by turoa »
Does anyone know where I can get a mechanical caliper? Im looking at converting the output of my t-case to disc from drum as ive gotten sick of adjusting the handbrake. I have a go kart caliper on a go cart, but its hydraulic. Can I get a mechanical one anywhere?
vando
Post by vando »
hi Tu, try the kart shops, or motorcycle wreckers. Some of the smaller bikes had cable operated discs too. I know some RM80's had them if thats any use? Cheers, Andy.
De-Ranged
Post by De-Ranged »
Hey T
Try any of the budget transport wholesalers for a trailer brake most of em will stock cable calipers and they will be bigger than bike or kart ones
I was looking at a supercheap one till I decided to make one :roll: :lol:
Cheers Reece
mroffroader
Re: Go cart/mechanical type caliper for disc t-case handbrak
Post by mroffroader »
turoa wrote:Does anyone know where I can get a mechanical caliper? Im looking at converting the output of my t-case to disc from drum as ive gotten sick of adjusting the handbrake. I have a go kart caliper on a go cart, but its hydraulic. Can I get a mechanical one anywhere?
I have a mate who works at a gokart shop. il try get you one... :wink:
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Early Subaru's have nice cable operated calipers on the front wheels. They are hydraulic as well of course but you just don't use that bit.
monaro427
Post by monaro427 »
you need something like this which i have just installed on my truck, a bit of bling it's probably worth more than the truck now,got this from the statesImage
Image :D
4x4 handbrake?
isnt that 1st gear low range :shock:
lowbox
Post by lowbox »
agricultural equipment suppliers have all sorts of stuff....
