cb radio help
kdub104
cb radio help
Post by kdub104 »
hi eveyone ive just fitted a gme gx300b cb radio to my 100serries cruza and had a stainless spring type aerial that i had off my old ute which i have used........
i cant talk to my guys in the skidder, dozer etc which all have cb radios or cant seem to even chat to my driver on ch11......is this because of the aerial ive used ? and have noticed i can hear engine noise through the speaker.....or is this an earth problem with the aerial?
please help all you radio gurus please.....dont want tait charging me for a silly fault...
cheers again
oldblue
Post by oldblue »
You haven't fitted a PRS ,CB Radio by mistake?
Steve_t647
Post by Steve_t647 »
it sounds like an aerial issue, you did use shielded coax cable? if you get engine noise it could be the amp has been damaged CB's don't like running without an aerial or a dummy load.
Best bet is to try the CB in another working rig (disconnect one in another vehicle and hook your one up) see if it goes good if not then I suspect the aerial amp and output may be gone if yes look at your wireing to the aerial.
you say you cant talk, can you hear anything other than engine noise? if only chat could be the mike.
Good luck
Dr46on
Stropper
Post by Dr46on »
Just looked that model up, it suggests that it is a 27Mhz CB & 27Mhz marine radio... Have you got it tuned to CB or marine? (Is there a difference?)
kiwipete
Re: cb radio help
Post by kiwipete »
kdub104 wrote:hi eveyone ive just fitted a gme gx300b cb radio to my 100serries cruza and had a stainless spring type aerial that i had off my old ute which i have used........
I would think there is a possibility that the old aerial you used is perhaps not the correct one for this radio. If I am right in my assumption, I think you may risk damage to your radio.
Ph 0212078472
kdub104
Post by kdub104 »
hi guys thanks for the replys
the aerial was only purchased 3mnths ago from dicksmith and sat on my hilux for 3mnths in the shed unused.....its a stainless coil type aerial so is this the wrong type?(they work fine on my prs radio?)the packet says it dosent need tuning?or does it?
i unplugged the aerial and still get noises and no its not in marine mode.
thanks again
oldblue
Post by oldblue »
Just a thought, is the squelch knob in the correct position?
Have you played with this knob.
TJ
Post by TJ »
kdub104 wrote:hi guys thanks for the replys
thanks again
CB aerials and PRS aerials are different, i.e. they are not interchangeable.
wjw
Post by wjw »
TJ wrote:CB aerials and PRS aerials are different, i.e. they are not interchangeable.
What he said
Who knew Prados could fly?
kdub104
Post by kdub104 »
ok cheers so what aerial should i use then for a c.b?
what aerial are most using on 4wd that have cb units?
the one that we used said its for a uhf cb with a 4.5db gain.....
Dr46on
Stropper
Post by Dr46on »
There is a huge range of aerials available for CB, you need one that states it is for 27Mhz band. The Db rating is basically it's ability to receive / send. Higher Db for longer distance, lower may help in hilly or built up areas. Dick Smith or Jaycar do a range, from a stainless type similar to the one you have (but in 27Mhz) to 1.6 meter long fibreglass whips. Cheapest start at around $27, and go up to what you want to pay. The other thing to think about is the mount point. If it is bolted to a bracket on the bullbar for instance, you need one that is ground plane independant. If it mounts in the middle of your roof, a ground plane dependant one will work better. It relates to how much reflective steel is directly below the aerial. I just got a 1 meter glass whip type from Jaycar, no tuning required, seems to work very well. (better than the 1.6 meter one I used to have)
kdub104
Post by kdub104 »
hey cheers for that mate
so im guessing the coax aerial cable can still be used or do i need to get another new cable aswell as aerial?
and its been mounted above the passenger guard bellow the winscreen and used a angled bracket.
nearly sorted cheers
kiwipete
Post by kiwipete »
Go back to DSE or where ever you got the aerial from and ask for one for the type of radio you have, you could even take the radio in with you so they can make sure you have the correct aerial.
Ph 0212078472
Dr46on
Stropper
Post by Dr46on »
Yep, the co-ax will still be fine
jdeburgh
Post by jdeburgh »
I assume you bought it here in NZ? So it is a 26mhz CB?
Like the others said, don't use a PRS aerial for it get 26mhz CB aerial there are many types and prewired with co-ax as well.
John
-Vehicle: Rangie - 4 Wheels, 3 doors, Engine, Gearbox, other whirly bits, Steering wheel, Radio, Seats, Pedal that makes noise, pedal thats stops it, and pedal that helps stop the crunching noise when using the gear lever.
http://www.feilding4x4.org
Return to “Tool Shed”
