Hi, anyone thought about makeing the Freewheeling hubs the weakest link by reduceing the number of splines on the inside of the clutch [dog ]?
My be easier to replace than CV axles.
As i see it, how would you know how many splines to remove?]
Makeing" Hubs" the weakest link
- muddyhilux
mhm not a bad thort there,in terms of how many teeth to remove,well,guess that would be a guess n check id say,maybe start with 1 outa 3,then maybe 1 outa 2,could be worth investigating and like u say,hell of alot easyr to replace from a 'on site' point of view,just the question of what would the hub ring do to the cv spline when it did let go??
http://www.warn.com/truck/axles/hub_fuse.shtml
Looks like warn have removed about 2/3 of the inside splines, lowering from 80,000 inch lbs down to 46,000 inch lbs. before they shear.
