94 Nissan Terrano-Power up
Creamygoodness
Stropper
Post by Creamygoodness »
Hi all I am looking at getting more power out of my 94 2.7 TD Terrano,I have heard just by adding an aftermarket air filter it will help?also I am on a budget :)Cheers all :)
wopass
Mmmm
Post by wopass »
:? more power from a 2.7td.....
step 1:remove 2.7td
step 2:fit briggs & stratton 4hp
you now have more 8) ....
but seriously.. :roll: plumb an intercooler into it and a pod filter and should go much better, not tooo costly if you have a bit of knowledge and do it your self :wink:
DieselBoy
Post by DieselBoy »
Make it breath better.
I did the injectors, pump timing, K&N, Exhaust, and increased the boost to 18PSI.
Huge difference!!!
Cheapest first:
Adjust the boost by winding the waste gate actuatng lever as far as it will go. Fit a cheap boost gauge ($20) to help set it up, it should get as far as 18PSI and no more, you run out of adjustment :wink:
Exhaust, take it to a shop and get them to cut the old silencers out and weld in some straight through ones($120). Ones you can see right through,ie no bends and switch backs inside.
Then fit a replacement element K&N that fits the standard air box ($150). Not a POD.
Take it to a diesel mechanic, tell him your not worried about smoke or fuel economy and get him to play with the pump.($112 Labour only)
Injectors are good to replace, but very expensive to do. About $60 per injector and the $$$$$$$ for labour. Around ($400 all up)
Makes a difference when they are set top the correct pressures!!!
It made a huge difference to mine, it powered 32 X 9.5 Simex centipedes fine all the way round the south island for a long time!!
