running on vegie oil
- mudda-trucker
- Bush Crasher
ok .. ive started to run my hilux desiel 2l on recycled oil. only hassle is every time i go for a drive i get the craving for fish & chips
. any ways with winter the oil is to thick and needs thinning down .. i need to make or get a fuel cell with a 12v heating element in it. dose any one know where i can get one from? or do you have any other idears for heating the oil.
there was a guy in pleasent point that got fully into the recycled/alternate fuel system for years, running everything from his tractor to his truck......
pinky might know of him ?? then again pleasent points a big big place
but yeah no relevance to the heating problem
be the man with the info though
i should beat you with a really BIG STICK for that conan points not that small as for the vege king i dont know BUT will know by tomorrow ( it's a small town ) a did find a site where a guy had his surf running on vege oil i will do a search ( couse i'm a nice guy ) and try to find it as it was an interesting article ....... live long and prosper
Just a chicken vs. egg thing, but the heat exchanger on the exhaust aint gonna work... its never going to heat the oil enough to start or run it because its not running to heat it up... and so on and so on
Something electrical will kill the battery in no time unless its almost like a glow plug timer setup and is just used to get the oil flowing, and the boys in blue aren't going to think much of a gas burner bolted up under the fuel tank
I'm fresh outta good ideas tho...
Steve
Steve
- Rotazuk
Many years ago some enterprising people ran there cars on alternative fuels during the gasless days . Bmc 1300 on something like diesel .
Anyway they had the main tank full of the alt stuff but had to have a small secondary tank to start the car on . Just swapped over to the proper stuff to start and once warm back to the alt stuff . The smart ones also shut down there cars on the good stuff , much like you used to have to do with cng etc .
This way a heat exhanger will work and it will still start well etc
Chris
Chris
Most fire trucks have a heating element in the sump, with a power cord which is plugged into mains power so it is always up to temp when they start up. If you have enough room in the sump to clear the crankshaft, you could put an electric jug element in the bottom, & plug into the wall for a couple of minutes before starting. Otherwise, wrap an old electric blanket around the sump overnight??
- mudda-trucker
- Bush Crasher
found
found a good site that tell you how to make biodiesel
http://www.humboldt.edu/~ccat/biodiesel ... steSP2001/
- mudda-trucker
- Bush Crasher
this is a better site for biodeisel http://www.biodieselcommunity.org/index.php
im off to the hardware store to pick up supplys. if you hear a big BANG this weekend .. its only me
Check out.
http://www.parker.com/racor/dfh_intro.html
http://www.diesel-therm.com/diesel-therm.htm
From the wesite.
All products are produced and sold under the name of 'Deltech Ltd. & LLP' in the USA and New Zealand.
http://www.plantdrive.com/
Good luck, with the way fuel prices are going it won't be long before we're all being followed by cats and dogs as we head down the road.
From the wesite.
This affect the performance much??? Looking closly at buyin a diesel 2 run it off vege oil. Petrol SOOOO Bloody ridulous $1.53!!!!!! you've gota b jokin!!!!
Neways enulf moaning mudda trucker do u get this oil for free?
- mudda-trucker
- Bush Crasher
im
i have run my truck on stright iol from the shop, it works but i has to be warned up- hence the need for a heater. now im tring bio-diesel, still working on my first batch... all most done. will keep you updated when i can.
[This affect the performance much] no i dont think it has
Hi All,
The Bio Diesel option begs the question!!
Was out shoppin with the wife last night
and ran into a family whose children she teaches. Met the Dad Duncan for the first time, swapped names and the usual "So what do you do??" and low and behold he makes bio diesel for a crust.
It might be a point of contact for those of you wanting to make some as he knows of where you can buy kits as well as the ins and outs of the fancy chem stuff!
His name is Duncan Berwick
Bio Clean Green Fuels
bio.fuels@xtra.co.nz
027 202 3069
Apparently he is making it by the ton and it is all sold. I wonder why??
027 202 3069
The current FUEL obsession
Now why shouldn't we just run our Diesel trucks on any old oil? I know that in previous trials they have run diesels for ages on plain old sunflower oil (in South Africa during the 1970 fuel crisis)....
I've run my Hilux on chainsaw bar lube on one occasion...not by choice, and it's a LONG story.
I suppose the rough oil will stuff the injectors eventually? What other problems will it cause? I figure we can solve most problems by running one tank fish oil, one tank diesel, and changing the fuel filter more often.
It's just if you're getting the oil for free or cheap, a set of new injectors now and again kinda makes sense, innit?
Besides, I'm sure my missus wouldn't want me out in the backyard playing with Methanol and Sodium Hydroxide... first one makes you blind, the second one blinds you.....
More on Biodiesel
Have been researching this topic a little bit. Found a really good website with clear instructions for making your own biodiesel - follow the link
http://journeytoforever.org/biodiesel_a ... l#easymeth
This is a helluva interesting link, even if you don't end up making any biodiesel.
Seems like you can do it easily enough, but it pays to get it right!
Answers to other questions:
Is veggie oil ok? Seems not. Very thick, increased pressure roots the injectors and diesel pump eventually. Not the thing to do unless you are a diesel mechanic.
Other critical factors? Biodiesel needs to be washed and filtered before use, and you HAVE to check the pH. Alkaline biodiesel will seriously screw with the diesel fuel system, pays to make sure it is slightly acid before use.
Anyone had a go making biodiesel?
Seemed nice and straight forward till I started to read this...blah blah explosions blah blah blah dangerous blah blah blah horrible accident blah blah blindness and death.
I kinda went off the idea from there
"CAUTION
Sulfuric acid is a DANGEROUS CHEMICAL. Take full safety precautions, wear safety goggles, gloves and apron and eye protection. Have running water nearby. Don't inhale fumes!
If you run out of sulfuric acid NEVER try to make up the required volume with nitric acid. It may form small quantities of nitroG (nitroglycerine) -- even the smallest amount can cause horrible accidents. See: High Explosives
Methanol can cause blindness and death, and it is absorbed through the skin. Sodium hydroxide can cause severe burns and death. Together these two chemicals form sodium methoxide. This is an extremely caustic chemical. These are dangerous chemicals -- treat them as such! Always have water running nearby when working with them. The workspace must be thoroughly ventilated. No children or pets allowed. Wear safety goggles, gloves and apron and eye protection. Do not inhale any vapors. See Safety for further information."
"CAUTION
Benjamin Franklin
Benjamin Franklin
There is a guy up north who has made biodiesel here are his details:
Peter Parsonage
batpro@clear.net .nz
http://www.partec.co.nz
Dave
Peter Parsonage
Dave
- mudda-trucker
- Bush Crasher
its not as bad as it sounds(reads) we have started to make a few small batches and so far so good, going to make a 200lt batch this week. will let you all know how its turns out.
- mudda-trucker
- Bush Crasher
set up cost ... 100lt hot water clinder (from the recycles) $30- new heater element $40- Methanol $80 for 20lt or $310 for 200lt- costic soda $26 for 20kg, and depends where you get your oil from it cost me $40 for 200lt.
+ say $200 for extra bits -
its working out for me at $0.37 per lt (+my time) take about 5 hrs over 4 days as i also work full time.
- mudda-trucker
- Bush Crasher
all my oil is used, get it from the fish and chip shops. you can also use fat but i havent tryed that yet.
Yeah, I figured it was do-able. It seems to be all about whether it's worthwhile to spend the time doing the work. I reckon if diesel gets to $1.50 a litre we'd be mugs not to have a go.
Besides, there's something cool about getting fuel with your fish 'n chips....
Is that a steel hot water cylinder, mudda? Is it galvanised?
- mudda-trucker
- Bush Crasher
the clinder i have is copper, ive been told NOT to use galvanised. something about the Methanol reacting with the metal.
wenseday the 12th oct we are gonig to make a 200lt batch will let you know how it gos.
- mudda-trucker
- Bush Crasher
yes you can blend if you want. most ppls have 2 tanks, startup on b-d and switch to deisel, but im gonig to run just one tank with b-d.
