Righto been a long time since an update so here is a list of stuff I have completed to date
7mge engine swap with fully rebuilt and balanced motor and hi volume (8.5litres) oil sump
New deck
histeer conversion in the front with new shock hoops tg springs and bilstein shocks
new longer tg springs in the rear with inverted bilstein shocks
custom front bar with 12000lb winch with amsteel orange rope, ali winch cover and hella comet 450 spotties
37in wranglers with staun internal beadlocks
lockright in the rear and 4.88 ratio diff heads
custom 3in steel snorkel connected to hi flow truck filter housing
arb compressor plumbed to on board air tank
oil pres, water temp, volt meter mounted in dash consol
hella rallye 2000 spotties on roll bar with rear facing hella wide beam work lights
4 point harnesses
things left to do
twin optima red tops to control winch
buy and mount ground anchor
front air locker
twin cases
longfeilds
exo cage
some picks
will post more pics later tonight
