I was taught a technique by an old fella years ago for removing seized engine studs, he would heat the casing around the stud with a gas torch for a few seconds and then apply a small amount of beeswax to the tip of the stud, the beeswax instantly melted and ran down the threads into the casing. he was able to then remove the seized stud bolt easily with his fingers using nearly no force! Amazing to see in action, it's as good as any magic trick.
Since then, i've thrown my can of CRC and now keep a lump of beeswax handy for bolts that have rusted or corroded in the threads and refuse to budge.
oh, you only need the area hot enough to melt the beeswax not vaporise it in a puff of smoke
