warricks recovery (pics)
basics
Post by basics »
my brothers mate txt me the other day while at work, and asked for a pull.
he had got his (old mans) ute stuck on a hill which then slid down the back into some pines. the hill was soaked.
after a couple attemps with the snatch strap decided to winch him up, only to find the ####### winch aint going. (is there a fuse with a winch? it makes a clicking sound just dosnt unwind)
in the end used heaps of sticks and pulled him to the top.
here are some pics
Mark
Moderator
Re: warricks recovery (pics)
Post by Mark »
basics wrote:my brothers mate txt me the other day while at work, and asked for a pull.
here are some pics
I bet those muddies are getting even higher on the priority list now :wink:
kaney
Post by kaney »
they are wrangler muddies arnt they, creepys look like the go if not
toymota thats stock standard.
ToySurf
Post by ToySurf »
The clicking noise your hearing is the solenoids, not a fuse. You may need to just clean the solenoid connections or replace the solenoid packs.
hiriklux
Post by hiriklux »
mine used to click because the solenoid was stuck a swift bash with the side of a stick used to sort it for a trail fix :wink: :wink: :wink:
basics
Post by basics »
ive taken all the gears out and im soaking them in deisel, tomorrow night i will grease em all up and put them in and see what happends.
solenoid are? :oops:
basics
Post by basics »
Mark wrote:I bet those muddies are getting even higher on the priority list now :wink:
they did fairly well, let them down to 15psi. but yeah, im on the look out hahah :wink:
BIG_BOY
Post by BIG_BOY »
big relays normaly that have a push or pull action to them for ingageing things as well like starters in to ring gears
Rocko
Post by Rocko »
I would of used a pully off one of those fence posts
