93 Surf 3l V6
surflover
93 Surf 3l V6
Post by surflover »
Hi Everyone,
I have just brought a 93 hilux surf ssr-g with a v6 motor in it, some people say that the heads are prone to cracking mine seems to run fine, btw its done 106000kms and its quite good i love it. I don't know if this is anything to go by but the temperature gauge stays a half all the time except in the mornings or cold. your thoughts please. :D :D
*I DON'T RING THE SHIT OUT OF IT EITHER*
SupraLux
Complete Bastard
Post by SupraLux »
You mean its always at half, even when its not running? Sound like a sticky gauge or crook sender. Probably best to get that checked because you REALLY want to know when your truck is overheating (or not heating up, ie: someone removed the thermostat, ie: possible head problems).
If you just mean its always at half way when driving at normal operating temperature then I'd say thats probably pretty normal.
Steve
eatenfuller
Post by eatenfuller »
HALF WAY ON THE GAUGE IS FINE :D
AND REMOVING YOURE THERMO IF ANTYTHING WILL TAKE THE ENGINE LONGER TO WARM UP (NOT MAKE IT RUN HOTTER :?: ) :?
SupraLux
Complete Bastard
Post by SupraLux »
Read the post properly...
NOT heating up, as in running cold...
Steve
[/quote]
surflover
Post by surflover »
In the morning it sits on cold but when i drive about a k at 60 kms/h it eventually goes to half, people say the heads on them are bad, but i'm getting a bigger exhaust for it from maggos from the manifold to the tip at the end
mike
Last minute Mike
Post by mike »
eatenfuller wrote: IF ANTYTHING WILL TAKE THE ENGINE LONGER TO WARM UP (NOT MAKE IT RUN HOTTER :?: ) :?
Not in all cases. I once had a mini with the thermo removed and it used to overheat, put a new one back in and overheating problem solved. What happens is that the coolant is pumped through the radiator to fast as there is no thermostat to slow it down and it doesnt get a chance to cool down before entering the engine again.
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
padero
Post by padero »
youd know if your heads were cracked.. my head gasket went last week and cracked the heads! cost an arm and a leg to fix $2200
things to look for :
1 - Dirty water in radiator
2 - possibly oil leak, will drop down on to drive shaft
3 - white smoke coming from exhaust all the time
4 - white smoke when Reving
5 - slight knocking noise
6 - feels wierd when changing gear
some jap imports havnt been serived proberly because there only kept for a short time and dont put anti frezze or maintain
All trucks can be prone to blowing things its just one of those things... and doing the things we do with our trucks can excellerate the general ware and tare on things.. which is why maintainance is of such importance, i know from now on i will be doing more of it
albundy
Rolly Polly
Post by albundy »
Lessons come hard don't they padero. Don't feel too bad about my clutch now. :lol:
surflover
Post by surflover »
Ok Thanks for the info,
Naa the engine Runs so quiet, once i didn't know it was on and i started it when it was on there is no smoke i revved it once just to the red line and my father couldn't see anything, it is so quiet and so much gruntier than my fathers terrano
hosehustler
Post by hosehustler »
surflover wrote:so much gruntier than my fathers terrano
Nice one :lol:
I hate signatures
cromcruiser
Post by cromcruiser »
the rest of them realy love the 3l v6 surfs get some big tyres and away you go :P :P :P :twisted: :twisted: :twisted: :twisted:
eatenfuller
:) het cromcruiser those simexs look good on youre wagon :D what size are they :?:
cromcruiser
:D Hi eatenfuller the tyres are 33/15/8 MONGRELS GOOD RUBBER :twisted: :twisted: :twisted: :twisted:
eatenfuller
:D :D yeah they look mean, so how wide are the tyres :?:
Jungle
Post by Jungle »
Hey eatenfuller. For someone who knows everything, I'm surprised you didn't work out the tyre size. Mongrels are a monoform tyres. Retreaded from bead to bead. They rely on using second hand tyres that are in good nick. Therefore the standard size is the 33x12.5x15 in a BFG or Dunlop or whatever else makes the standard. Thats 12.5 inches wide!
And Steve is right. Not sure why we bother with you!!!!!
G
DieselBoy
Post by DieselBoy »
:cheers: Cat Fight :cheers:
:instagib:
Return to “Toyota”
