Nissan PTO Winch
GQTROL
Nissan PTO Winch
Post by GQTROL »
Have two Nissan PTO winch setups (GQ / Y61) that are no-longer needed, so are for sale here before they go on TradeMe.
Includes:
Winch unit, drive-shaft, PTO output, lever and cable for engaging output. No winch cradle for it to be mounted in. The bracket for the hanger bearing has been gas-axed off one driveshaft, bearing is still attached, just the bolt holes where it attaches to the chassis isn't. Am selling them for what they owe me.
Can freight / courier if necessary, but they are a heavy heap o shit so would cost a fortune.
Ring or PM is the easiest way of getting hold of me.
Mitch
027 392 1296
mudchuka
Post by mudchuka »
how much are ya looking at?
GQTROL
Post by GQTROL »
PM sent
Jafa
Post by Jafa »
Are ya goin away from the PTO?, or have ya something else up ya sleeve for ya comp truck?
021 273 9942
jafa@inspire.net.nz
GQTROL
Post by GQTROL »
Jafa wrote:Are ya goin away from the PTO?, or have ya something else up ya sleeve for ya comp truck?
I'm no-longer co-driving in that race truck, so these are surplus to requirements, hence their sale.
Nothing wrong with the PTO once they're set up right. If you threw an extra gearbox in there to tripple the line speed, you would be away laughing.
Mark
Moderator
Post by Mark »
Do you know if it's possible to put a PTO on an Auto?
GQTROL
Post by GQTROL »
Mark wrote:Do you know if it's possible to put a PTO on an Auto?
Not on a standard Nissan auto.
The Alison 1000 auto-trans found behind the 6.6L DuraMax engine in a few yank tanks have covers for two pto outputs though. But they're $2.5k each...if you can find them!
monstr
Post by monstr »
Hi,I was looking at a late model Nissan Civilian bus a while back,It was powered by a td42 and auto (factory) It had a PTO plate on the gearbox,I dont know if the drive gear was inside ,but would be worth checking out//..Cheers...Steve
