I positioned the little bottle jack directly under the U bolt bracket for the springs and by the time the wheel was off the ground by about an 30mm the jack was maxed out.... this can't be normal can it?
This was on pretty much perfectly flat ground too, I figure this jack would be all but useless off the road!?
I've seen those high lift jacks that guys have but as I under stand you need certain jacking points to use them??? Is there any other options for a jack to be left in the truck all the time?
I guess I'd better get the jack sorted before tryin to fit new leafs etc.
Ryan
