Maybe that's what they weren't on there when I got it? The previous owner used shackles on that hole just above the hook.
Also it had a pintle visible in this shot
But I took that off as I couldn't tow a trailer with it on.
I was thinking of cutting that rear bar and recessing the pintle against the original chassis crossmember - I know it sounds crazy to cut a solid bar but if I can't tow a trailer its no good. I'll leave as much steel there as possible but if it goes that far forward then I can use both, and it will be mounted to the original factory tow point anyway.
Are pintles suitable for snatching with?
Also are the front hooks (think they are factory) suitable as they are?
They are not stamped with a rating but are the same design as the hooks you buy and I understand from tests done that those with a stamp and those without were very little different?
Just throwing up some thoughts for comment here - thanks
